help with soundcard
First post, by scroeffie
i have a mistumi soundcard with the cd rom drive 1 speed
and also a soundblaster 16 ,the cdrom card has the cd audio cable hookt to the cd rom drive
but how do i get cd audio to the soundblaster 16 card ,do i buy 4 speakers that makes no sense
the cd rom isa card also has audio output ?!
it just makes no sense
and where to find the drivers for the mustmui cd rom drive 1x speed
Reply 1 of 41, by cyclone3d
What is at the other end of the audio cable that is plugged into the Mitsumi card?
Looks to me like there are two cables and one should go to the CD-ROM drive and the other to the sound card.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 41, by scroeffie
thats makes sense to me what you said the audio cable is going from the sounblaster card to the cd rom drive ,but than whats the point of the cd rom isa card ?
because when i got the pc the cd rom cable was going from the cd rom isa card to the cd rom drive !
Reply 3 of 41, by Jorpho
scroeffie wrote on 2020-12-01, 18:26:
Because back then some people wanted to have a CD-ROM without also needing a sound card?
Reply 4 of 41, by scroeffie
makes sensen ,so the audio cable from the cd rom is going to the soundblaster 16 card ! and the ide cable from the isa soundcontroller is going to the cd rom drive
Reply 5 of 41, by Grzyb
The CD-ROM controller interface on CT1740 is for Panasonic/Creative drives, not for Mitsumi.
The analog audio input, however, should also work with a Mitsumi drive - but make sure to check the pinouts, as a different cable may be necessary.
Reply 6 of 41, by scroeffie
oke i installed the soundblaster driver and the soundcard is working perfect ,i also installed the mitsumi cd rom driver but it wont work i think there is a conflict !?
not shure what to do ,how do i solve this
Reply 7 of 41, by scroeffie
Reply 8 of 41, by Jorpho
Is your CD-ROM drive plugged into one of the IDE connectors on the motherboard?
As noted above, the IDE connector on the sound card will not work with this drive.
Reply 9 of 41, by scroeffie
no the mistumi cd rom drive has its own controller card witch is plugged in i installed the drivers with succes but it wont give me a letter ,i think there is a conflict with the sounblaster thats as far as i get
Reply 11 of 41, by scroeffie
so the dma switch on the controller needs to be off or on ?
Reply 12 of 41, by cyclone3d
scroeffie wrote on 2020-12-09, 22:36:
The CD controller card looks like the DMA jumper is set to 7 which should be fine. Guessing you need some command line switch for the controller driver to specify DMA 7... maybe DMA 5 is default.
YMF7x4 Guide
Reply 13 of 41, by scroeffie
when i was installing the driver it gave me allot of options to choose dma irq etc etc just allot of things i have no idea i just pressed enter couple of times
Reply 15 of 41, by scroeffie
dont know where to find this file 😀 its this i think ?
Reply 16 of 41, by scroeffie
any one can help me figure this out
Reply 17 of 41, by scroeffie
help
Reply 18 of 41, by jmarsh
It's asking what DMA channel to use and from your photo the card is set DMA channel 6.
Reply 19 of 41, by scroeffie
the software says channel but the card has no channels !?!?
i changed the jumpers and now i got this stil not working i think !?!?
