First post, by Deadly_Miho
Greetings everyone,
lately I’ve been making an effort to get my old Pentium P54C (90Mhz) machine (S3Trio64V+ graphics card, Sound Blaster 2.0 Ct1350b (A220 I7 D1 T3)) set up and running with Win 95. In the integrated
DOS mode I wanted to play Indiana Jones and the Last Crusade (256 colours VGA) with the Adlib sound parameter set in the command line. While Fate of Atlantis and other games such as DOTT seem to play Adlib sound just fine, Last Crusade (and also Secret of Monkey Island) produces a noise that sounds close to the intended end result, but also really off.
I’ve been messing around with Sound Blaster 2.0 drivers a lot to even get to this point, so I’m pretty sure that those are installed correctly and I also double checked that the Config.sys file and autoexec.bat include the relevant lines as described in the Sound Blaster 2.0 manual. One thing I did notice however is that in the test-sbc app found within the driver package there is no FM synth music output, not entirely sure why that is the case (OPL-2 chip is installed on the card btw). Maybe I’m missing something really obvious, I’m not overly familiar with old Hardware after all, but I was hoping I could get some advice with regards to the sound issue at hand.
