diamond dt0398
First post, by Nemo1985
Hello, I've got this card, but it seems quite obscure, it is pci and there are some jumpers on the card, I tried to find an online manual but without success.
It also seems to have a sblink connector but it has all the 6 pins populated.
Any help, please?
Reply 2 of 4, by Nemo1985
Thank you for the tip!
It has some other jumpers too:
The 6 pins near the jumpers are a sblink port in your opinion?
Reply 3 of 4, by SScorpio
I found the manual as a DOC file included in the zipped drivers for the card. I converted it to PDF.
That 6 pin header block is labeled as PC_PCI, but it doesn't say what the jumper above it does. It's likely an enable/disable.
The manual does list the speaker/line-out settings, as well as the pinout for the audio input headers.
Reply 4 of 4, by Nemo1985
Thank you very much!
I will try the sb link cable then in a way or another it should work
