WP32 McCake : MT32 compatible waveblaster board
Reply 180 of 429, by RetroGamer4Ever
I'm gonna order this and the X2GS with the external adapter cases, as a Birthday present for myself. I always wanted the best MIDI hardware available, but it was long gone from shelves by the time I was able to afford any of it.
Reply 181 of 429, by Salient
RetroGamer4Ever wrote on 2021-08-02, 13:52:
You won't regret this decision!
Reply 182 of 429, by aitotat
MT-32 mode seems to have left and right channels reversed but fluidsynth mode does not. It is easy to test with Wing Commander. In the room where water drops to bucket the drop sounds are on left channel but the bucket is on right side of the screen. When switching to fluidsynth mode the water drops are on right channel (but of course intruments are wrong in GM mode but this is only for testing left and right).
Reply 183 of 429, by d0pefish
aitotat wrote on 2021-08-06, 08:55:
This is correct, there is no bug here (except maybe in Wing Commander). The 'drops' come out of the left channel on my real MT-32.
As for FluidSynth/MT-32 panning being opposite to each other, again this is correct. The MT-32 interprets MIDI CC#10 (panpot) as 0=right, 63=center, 127=left. It is believed that early versions of the MIDI standard didn't define what these controls should do, so Roland just went with this scheme for the MT-32.
Later versions of the MIDI standard (and therefore later devices released after the MT-32, e.g. SC-55) explicitly defined CC#10 to be the pan control and to interpret 0=left, 64=center, 127=right. You can verify this by comparing the MT-32 and SC-55 manuals and reading the MIDI spec.
Chances are that Origin just forgot to invert the panning messages in their MT-32 music driver.
Reason: Restoring revision 146076
Reply 184 of 429, by aitotat
Thank you for the great information. Good to know it works just like it should. Would it be possible to add custom sysex to reverse stereo with mt32-pi.exe? Just a one more little thing to make it better than original.
Reply 185 of 429, by d0pefish
Yes, it should be possible to do that quite easily. Munt has a useful reverse stereo function which I can simply expose in SysEx/config option.
On my list for the next release.
Reply 186 of 429, by dreamblaster
New revision McCake : a few size optimizations :
- moved drive bay panel connection to the side, to allow more clearance at bottom.
- moved display to position under the CM4, to reduce total thickness of the setup
Thanks for your support !
Reply 187 of 429, by bnz99
I think the improvements are very good. What I started to wonder when doing my custom floppy bay is whether the pins wouldn't be better in a 2x5 IDC connector layout. They'll possibly take slightly more space, but it's much easier to actually get those cables and they are pretty cheap. Plus having shrouded pin headers on both ends would be a little more user friendly.
Reply 188 of 429, by dreamblaster
bnz99 wrote on 2021-08-08, 07:17:
yes thats a good idea, except it adds height, i really want to avoid that.
see photo how my setup is, in fact the panel is ready but suitable ready to use cables are not available.
can you think of other, low height, low cost, cables that could be used ?
or is the added height for IDC connectors acceptable?
Reply 189 of 429, by bnz99
Hm, true point. It's probably thick enough already for the next slot to be used. The problem is that many cables that are not IDC are likely again trouble to source or not long enough. The only idea I can come up with is possibly an FFC/FPC-10P connector on the WaveCake with a short flexcable that leads to an actual IDC adapter where it isn't in the way. That additional adapter surely isn't exactly nice either, but at least this stuff can be bought for cheap on AliExpress and there probably isn't any additional height due to the connector.
Reply 190 of 429, by dreamblaster
yes that would be a solution but also not ideal.
Reply 191 of 429, by igna78
Hello everyone, I was reading what has been said so far and looking at the project, and a thought occurred to me 🤔: if WP32 McCake is a waveblaster board, then it is inside the pc, why not remove the screen and buttons from the board to get more space to dedicate to the connector for front panel where is screen and buttons? (of course if the intention is to sell WP32 McCake bundled with the aforementioned front panel).
However, I think that a screen and buttons on a card inside the PC are of little use (These are just extra costs ) 😉
Reply 192 of 429, by dreamblaster
igna78 wrote on 2021-08-08, 10:36:
However, I think that a screen and buttons on a card inside the PC are of little use (These are just little extra costs ) 😉
Hey
yes, but pcb space is not the problem, it is avoiding height
Reply 193 of 429, by igna78
Excuse me, from the last photo you posted, it seemed to me that by removing the screen, you would have recovered space (I also meant for the height of the connector) .. the photo from above deceived me 😁
Anyway as soon as this wonder is finished , there is a pc in Messina (Italy) waiting for 🤣
Reply 194 of 429, by dreamblaster
currently the floppy molex connector is the highest point
Reply 195 of 429, by bnz99
How about a usb-c socket? Maybe misusing those pins for something else is something that works...it's reasonably flat.
Reply 196 of 429, by igna78
dreamblaster wrote on 2021-08-08, 11:54:
Thanks for the photo, now I am well aware of the heights in play .. actually the screen and buttons play little on the height (or thickness) 😅
At this point, the thickness of the design could hardly be reduced further 👍
Reply 197 of 429, by 640K!enough
dreamblaster wrote on 2021-08-08, 07:34:
Why not a right-angle IDC connector? In surface-mount form, they shouldn't add more than a few millimetres to the overall thickness of the whole assembly. Using the unshrouded variety would reduce that slightly, as well. If it's really a concern, then try varying the number of rows used, or the pin/row pitch.
Reply 198 of 429, by bnz99
It's actually true. I have tested a two-row right angled socket against the floppy connector and the floppy connector is still higher. So an unshrouded 2-row right angled pin header might not be as high as we thought.
Reply 199 of 429, by RetroGamer4Ever
Go ahead and take your time. This is obviously more complex than a DREAM-based synth card, so you might as well try some things out before you commit to mass-manufacturing. I myself have no use for the buttons and display, but I understand the reasoning behind them.
