Recording PC Speaker?
Reply 20 of 26, by SMA
SMA wrote on 2022-04-07, 15:30:
I think, better is using the SilLabs SI8910 insulated amplifier… and we need additional Nyquist filter in case of infinite spectrum of the Delta function.
SilLabs SI8920 used.
I draw some schemes using KiCAD 6.0.2... https://www.kicad.org/
Any comments are welcome. The PCB Layout is not designed at this moment. Please check availability and pricing in your country for used components before I start design the textolite.
Please comment what class (trace width / spacing) are availible for your production.
I want trace in two layers.
Reply 21 of 26, by SMA
I am sorry — I was asked the question, but not upload any BOM (Bill Of Materials).
New schematic arrived. I hope this is final schematic revision and future updates are PCB only.
Changelog:
rev-03
PSU replaced by isolated module — now all power brings from OLD PC 3,5" floppy connector.
Some comments and graphs are added.
rev-02 (unpublished)
Double check all math and correct mistakes.
rev-01
Initial release.
Reply 22 of 26, by creepingnet
I've been known to capture it by routing through a sound card like a SoundBlaster and using the mixer to mix it with the signal. I also have made my own simple mono cables too for PC's without.
Sometimes to try and reproduce/make it sound more authentic I use a guitar effects processor with just a little bit of reverb and a slight E.Q. to make it sound like a PC in a room rather than some kind of home-made monosynth project.
~The Creeping Network~
Reply 23 of 26, by SMA
creepingnet wrote on 2022-04-12, 02:21:
It is, probably, excellent solution. Not only SB supports record from PC Speaker. Some other sound cards also have, at least, function to play PC Speaker to line out.
Reply 24 of 26, by SMA
SMA wrote on 2022-04-12, 00:57:
Final revision probably...
Changelog:
rev-04
PCB design finished (bottom layer are optional — should be workable with front copper only).
PCB design compatible with "Laser-HotIron" prototyping method.
Schematic diagrams for Cables added.
rev-03
rev-01
Initial release.
Reply 25 of 26, by SMA
SMA wrote on 2022-05-22, 19:18:
Major remarks for Rev.04:
1. USB cable for PowerBank only! Not for wall charger. Not for PC USB port.
2. Output is not compatible with phantom power.
3. Originally designed for powering from Old PC floppy connector (from signal source, not from recorder).
Reply 26 of 26, by Jo22
Thank you very much! 🙂👍
