Reply 220 of 590, by shock__
Scali wrote:
Fagear wrote:
For fully-assembled cards I also need to know, what SID will be installed in it. Because with 8580 there must be a 78L09 reg and filter caps 6.8nF, but for 6581 there must be short on +12 and 1nF caps.
Would it be possible to design this in a way that you can easily switch between SID types using a jumper or something?
I can imagine that people may want to swap between a 6581 and a 8580 from time to time.
Just add "sockets" for the caps, that way you can switch them as easy as the SID. The HardSID Quatro was like that: http://pics.studiorepair.de/Interfaces/slides … Quattro_ISA.jpg (might be hard to see)
Hard-wiring the voltage for the SID is a good thing in my eyes, that way less 8580s will get killed by accident.
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 222 of 590, by Beegle
carlostex wrote:
Oh you had to tease with the AdLib Gold, huh? 😈
yeah... not really I just took what I had on my desk at the moment 😀
Good catch!
I have ordered my SID chip, and I was told to be super careful with it, apparently they're super sensitive to static electricity.
Aside from grounding myself when touching and manipulating it, anything else I should know or do?
The more sound cards, the better.
AdLib documentary : Official Thread
Youtube Channel : The Sound Card Database
Reply 223 of 590, by Fagear
I think current board is final.
I'm thinking about another SSI-2001-compatible board: smaller, SMD, more SID clock options and easily configured. But that's just a thought right now.
Well, common precaution working with ESD-sensitive devices. Wear minimum clothes from synthetic fabric, minimize fast motions of your body. Use grounding strap or regularly touch grounded parts with your hand (PC case, back of power supply) before touching everything else inside PC. Store and handle ESD-sensitive device (SID) in static-dissipative package and/or with shorted legs (put them in metal foil).
Typical scenario:
1) You take package with your SID (presumably packed into static-dissipative, "silver" packet) with one hand;
2) Go to your test PC with your replica, down touch it yet;
3) With another hand touch case of your PC or power supply casing (shortest path to grounded power outlet): warning, spark may occur! 😈
4) While touching grounded part (keeping potential of your body near ground level, also SID in you other hand will be equalized with that potential safely as well) sit down and put your SID onto PC.
5) While regularly contacting your body with grounded part, unpack your SID and put it in the board; avoid fast motions of your body;
6) Put the board into PC;
7) Done!
New BIG soundcard: FMonster.
Covox Sound Master replica
Innovation SSI-2001 replica & DuoSID.
My audio/video collection.
Reply 225 of 590, by shock__
Another tip: Make sure to only touch the plastic/ceramic of the chip, not the pins itself whenever possible.
In any case, even that may not help. I just picked up 5 SIDs for Fagear, which were new (not _like_ new, virtually new, unused old stock - late '92 datecodes, pins still slightly bent outwards, according to the seller old stock they bought at the German Commodore plant in Braunschweig) ... guess what - 2 of them were broken. Getting free replacements tho 😀
But yeah, we're talking about 23+ year old chips which weren't the most reliable even back in the day.
[Z?]
Reply 226 of 590, by keropi
is it a good idea to fix a heatsink on the SID? If I remember correctly I saw some users doing that on their C64s...
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 227 of 590, by Great Hierophant
I ordered mine and have a SID on the way too.
I suppose no one is interested in writing a DOS or Windows 9x SID player so we use this card as a playback device for HVSID.
Reply 228 of 590, by Fagear
Fagear wrote:
And I have some examples of sound: Lambada.sid and 1988_Top_40_MEGAMIX.sid.
Real hardware, new board with MOS6581R4 in it. Playing *.SID file with bristlehog's alfa-version software.
bristlehog is working on it, but he has very little time for this now.
UPD.
And I tested some HardSID-compatible software and of course it doesn't recognize the replica and doesn't play.
Reply 229 of 590, by shock__
It certainly doesn't harm. Even though it's probably not the cure of all problems either. It probably has a slight positive effect on long term usage as lower heat means lower stress on the DIE inside the package - being that heat should always be within specs anyways it's doubtful that a heatsink might save a chip from otherwise catastrophic circumstances ... just be aware there's a lot of tell-tale and folklore surrounding the SID.
[Z?]
Reply 230 of 590, by bristlehog
I'm already writing a DOS player. However, it turns out that this player requires a 500 Mhz CPU to operate properly (otherwise it would play slower than normal). Is it that a big problem for the community?
Here you can get fantastic wallpapers created by a friend of mine: patreon.com/Unpocodrillo
Reply 231 of 590, by keropi
^ really? 500mhz?!
there goes the dream to use the card in my p200mmx build
Reply 232 of 590, by bristlehog
keropi wrote:
^ really? 500mhz?!
Perhaps if I use another, less demanding C64 emulation library, there's hope to make a player suitable even for a 386. But the current version (based on libsidplayfp) requires a 500 Mhz CPU.
Reply 233 of 590, by Fagear
I need to say: it requires exactly 500 MHz or a little faster CPU. Because on faster CPUs it plays faster than normal. 🤣 At least version that I have.
Reply 234 of 590, by bristlehog
Yes, I am working on time sync that would allow it to work on CPUs faster than 500 Mhz, but I can't do anything for slower ones (apart from writing it from scratch with another C64 emulator).
Reply 235 of 590, by keropi
why do you need a c64 emulator? how does the player works?
Reply 236 of 590, by Great Hierophant
That makes sense because you need to accurately emulate the 6510 CPU, the 6569 VIC-II and the 6526 CIA. A SID file is mostly 6502 program code plus data, so it utilizes 6502 based instructions and relies on either the VIC or the CIA for timing.
Of course, many SID files are written for PAL timing in mind, which the Innovation does not support.
Reply 237 of 590, by bristlehog
As Great Hierophant already mentioned, SID files are C64 binary code. The player has to create a virtual C64 environment for that binary code to work. Thus, some open source C64 emulator can be taken, extra parts (like SID emulation) thrown out of it, and interaction with SSI-2001 added.
Reply 238 of 590, by keropi
ah, now I get it. it's a shame.... I thought that sid files where something like midi files.
Reply 239 of 590, by bristlehog
What is HVSID by the way?
