I have finally been able to make a recording, and upload it the net. I chose Doom E1M1, using a SB Pro 2. I appreciate it's not required by anyone, but I thought I would upload it anyway. It's only 40 seconds.
http://www.multiupload.com/0M8FXZOC3P (I tested the Hotfile link, and it worked.)
I compared my recording to the recording found on Swaaye's website, and it could easily be my imagination, but is my recording fractionally cleaner sounding? The settings I used were:
SB Pro 2 sound wheel set to maximum.
SB Pro control version 1.21 - master, voice, fm, cd volumes all set to default value of 12
Using Sound Blaster Which.exe program, the hardware is reported as:
Sound Blaster Pro v3.01 (stereo)
Min rate 4000
Max rate 22050
Mixer = Present
Sample size 8 bits
Audacity recording set to "what u hear".
During recording, I muted all other sound channels using X-Fi control panel, and the Audacity microphone recording level sliding bar was set to Max. I exported the recording as a WAV file (leaving all settings as default, the VB Rate at 2), and used LameDrop to change it to an MP3.
Very special thanks: Malik, thanks very much for this sound card! 😁
