Reply 260 of 314, by appiah4
- l33t++
CU_AMiGA wrote on 2022-06-19, 23:26:Hello. I don't think i have a problem, but more of a query. Hence why i am going to post this in this thread rather than create […]
Hello. I don't think i have a problem, but more of a query. Hence why i am going to post this in this thread rather than create a new one. I have an OEM ISA PnP ES1869F card which seems to be functioning fine. I have a dual bootup setup - Windows 98SE, and pure DOS. I have set it up just fine under Windows 98SE via the OEM VxD drivers. Now for DOS, i can't seem to change any of the settings/parameters in the ESSCFG utility that is used in my autoexec.bat (even by using the ! command - complains of an incorrect parameter). And on bootup, ESSCFG says ES1869 is configured by PnP or ICU. Luckily my ES1869F card seems to be configured correctly for use (IO:220 I:5 D0:1 D1:3 MPU:330 J:E), and games seem to find/work fine on it just fine: music, sound effects, and external MIDI wavetable. Tried the usual suspects, Doom, Duke 3D, Lemmings, Keen 4, few others - no issues (unless anyone can think of any other games to try?). So my question is, do i really need to include the ESSCFG in my autoexec.bat still if its correctly configured by default? I currently include it just to confirm/show it configuration on bootup, along with the ESSVOL settings. So the section in autoexec.bat looks like:
C:\AUDIODRV\ESSCFG.EXE
C:\AUDIODRV\ESSVOL.EXE /v:8 /l:0 /w:8 /m:0 /c:8 /s:8 /a:8 /p:0
C:\AUDIODRV\ESSVOL.EXELet me know guys, thanks! 😀
Thanks for your time.
You probably don't. How about REM'ing that line and trying, for science?
