First post, by Aglenoth
Hello Everyone, since I am really lazy and have not forced myself to disassemble my current DOS-PC I would love to ask if I should swap my ESS1868f sound card with this SoundBlaster one, is it worth,and does it have the hanging note bug ?
Also are drivers available for this card ?
Any help is highly appreciated 😀
Pentium II 266 MHz
Diamond Voodoo Monster II 12 Mb
S3 trio 64v+ 2Mb
ESS AudioDrive 1868f
10Gb fireball HDD
256 Mb Ram
Reply 1 of 6, by jesolo
Yes, it does have the hanging note bug but, it is less noisy than the older Sound Blaster 16 cards.
It also uses Creative's CQM synthesis (i.e., doesn't have a real Yamaha OPL3 FM synthesis chip).
Reply 2 of 6, by Aglenoth
And how bad is the emulation ?
Pentium II 266 MHz
S3 trio 64v+ 2Mb
10Gb fireball HDD
256 Mb Ram
Reply 3 of 6, by derSammler
The ESS1868 has less noise, no bugged MPU-401 and FM is much closer to OPL3 than CQM is. Why do you even consider replacing it? Unless you want the Sound Blaster for the sake of having a Sound Blaster, you would lose more than you gain. (you only gain SB16 support anyway, at the expense of losing SB Pro stereo).
Reply 4 of 6, by gerwin
I have one with OPL3-L, it may be very uncommon though.
Reply 5 of 6, by Aglenoth
It seems like mine has Yamaha opl chip too
Pentium II 266 MHz
S3 trio 64v+ 2Mb
10Gb fireball HDD
256 Mb Ram
Reply 6 of 6, by Jolaes76
http://vogonsdrivers.com/getfile.php?fileid=13&menustate=0
but there are other driver packs there that might work as well.
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
