Auzner wrote:Like FM? Not with software to a sound card. These sorts of things also require licensing to broadcast. Are you simply just curious or is there a mission statement for having a form of wireless audio?
Actually, FM transmitter kits are pretty common: https://www.canakit.com/fm-transmitters
Most of those will hook right up to the line output of a sound card. Anything under 1W is legal in North America and most of the EU.
I’ve seen some kits that do 5 to 10W, which, with the right antenna can give a pretty decent range (especially if you’re broadcasting from a high rise in a densely packed city). You can also buy 50 and 100W power amplifiers, which you would place before the antenna, to greatly increase range. However, using one of those will get you a visit from “the man” and a hefty fine, so use at your own risk.
As always, check the applicable laws from the body governing the RF spectrum in your country, as they vary.
Any sufficiently advanced technology is indistinguishable from magic. (E.g., Cheez Whiz, RF, Hot Dogs)
