First post, by xjas
I have Yamaha's S-YXG100 softsynth set as the default MIDI device under Win 98SE. I'm trying to get DOS programs running in a window to play MIDI through it. I feel like there should be a way to do this but I'm failing hard at figuring it out. The machine is this one with a VIA / Realtek AC'97 chipset (VT8235), which does give Sound Blaster support in a DOS window, but I'm not sure it's providing any MPU-401 or even SB-MIDI emulation. (The M-Audio Delta 2496 in the machine doesn't have any DOS support at all.)
I think I need a 3rd-party patch bay; I tried MIDI Yoke but couldn't get it going through that. Very unintuitive program.
What's a good way to make this work?
Reply 1 of 5, by kwiniarz
I'm having the same issue. I just can't figure this out for some reason. No MPU-401 virtual driver for my sound card. MidiOX works just fine using the external midi device in windows.
Reply 2 of 5, by NJRoadfan
You can't.
I battled with this back in the day with my SB Live! and a Roland MT-32 under Windows 98SE. Basically its whatever the sound card driver is hard coded to. My solution was to run Windows 2000 and VDMSound, which created a virtual MPU-401 interface for the VDM and allowed routing to any system MIDI device.
Reply 3 of 5, by kwiniarz
Bummer. I thought that was going to be the case. I will try VDMSound Alpha for win9x. if not, win2k it is.
Reply 4 of 5, by kwiniarz
VDMsound for win9x for the win. works great!
Reply 5 of 5, by xjas
kwiniarz wrote:
VDMsound for win9x [...]
Well THERE'S something I didn't know existed until just now. Will give it a try when I get some time.
