First post, by anetanel
Hey all.
I got this "Super I/O" card with an "Acer M5101_A2" chip in my 286. It has a Game Port socket, but when I connect a MIDI device to it (I have an MT-32) it does not work. As in the MT-32 does not indicate any communication.
When I put an SB16 in this machine, and used its MIDI port the MT-32 worked without problems, without any drivers or configurations for the SB16.
I ran Dune install and it tells me that it can't initialize the MIDI card. Neither on port 330h nor 300h.
Does it mean that the Super I/O card does not support MIDI? Or is it a configuration issue?
There are no jumpers on the card to configure anything.
Thanks.
Reply 2 of 6, by darry
Not all game ports have midi functionality . It was a trend that was introduced on sound card game ports by Creative Labs with the Sound Blasters featuring DSP 2.0 (as far as I know). Most sound cards followed this trend afterwards . I doubt any (Super) I/O cards had midi functionality on their game ports .
Reply 3 of 6, by anetanel
That's good to know. Thanks!
Reply 4 of 6, by yawetaG
Oh well, that answers my question here, in a sense. 😀
Reply 5 of 6, by Great Hierophant
Not quite correct. The Sound Blasters always had some kind of MIDI port, from DSP 1.05 on upward. I believe DSP v1.05 is the earliest DSP found on production cards. However, the Sound Blaster MIDI ports did not support any kind of MPU-401 compatibility until the Sound Blaster 16. The proprietary Sound Blaster MIDI standard was not well-supported in games.
Reply 6 of 6, by darry
According to the Sound Blaster hardware programming guide, you are indeed correct, but there are limitations as to the degree of functionality prior to DSP version 2.00 .
"SB-MIDI mode provides an interface for MIDI I/O in Normal mode as well as UART
mode. UART mode requires a DSP with a minimum version of 2.00. Under Normal
mode, all MIDI out data must be preceded by a MIDI output command, but under
UART mode, a write to the DSP is taken as MIDI data."
from section 5-2 of https://pdos.csail.mit.edu/6.828/2011/reading … oundBlaster.pdf
