First post, by bionicle_159
I've purchased an old 2006 X-Fi with the classic Soundblaster front panel and of course straight after LGR posted a video on it - pointing out the proprietary mini-din connector for MIDI devices!
I would really appreciate someone to do a simple write-up of the pin-out as this would save myself a big headache with dealing with eBay sellers, as the prices for the adaptor cables are annoyingly high on eBay UK for what is essentially a simple wire conversion.
Work Rig - Ryzen 2700X, 16GB 3200Mhz, MSI B450 LN91340, HD 7970 Ghz (I know...), SB 1500
XP Rig - C2Q Q6600, 4GB 800Mhz, GA-P31-DS3L , GTX 750Ti, SB 0820
98SE Rig - AthlonXP 1700, 512MB 166Mhz, NForce A7N8X-X, V3 2000 PCI, Aureal Vortex 2 SQ2500
Reply 1 of 18, by Salient
I measured my own cable and came up with this:
Male mini DIN:
Female DIN end:
I only use the MIDI out of my X-Fi so I am not totally sure if the other conversion cable could be different but as I recall it, they are both the same and not specifically labeled for MIIDI IN or MIDI OUT.
Reply 2 of 18, by bionicle_159
so are the blank pins ground?
Reply 3 of 18, by Salient
Blank pins are not connected anywhere.
Reply 4 of 18, by bionicle_159
Thanks for clearing that up for me, I knew I could count on VOGONS for support! I'm sure this will help a lot of people who are bound to run into the same issue. I'll order the connectors in the next few weeks, perhaps in the future I might design a low-profile 3D printed block adapter that simply plugs into the recessed area of the front panel MIDI port.
Reply 5 of 18, by bionicle_159
*This may come across a bit daft but what is the blue section for? I was under the impression that the notch was just for lining up the connector, not having any electrical relevance.
Reply 6 of 18, by Kamerat
Usually that's connected to the cable shielding.
YouTube channel
Reply 7 of 18, by Tiido
Shields and grounds are to be connected only on one end (one connecting to MIDI out) on the MIDI cables to prevent ground loops from happening.
Reply 9 of 18, by bionicle_159
OldDog_Rigo wrote on 2020-10-05, 05:40:
Hi there, just wondering if there was any chance i could get those mini MIDI to Standard MIDI drawings? I also have the front panel inputs but no cables.
Thanks.
Couldn't find a web archive, but here's a link to a manufacturer, not had any luck in getting replies though.
https://m.alibaba.com/product/60697438789/lin … .b1b748dahuD3ZT
Reply 10 of 18, by Srandista
Thanks.
Here you go:
Male mini DIN:
36.32 KiB
Female DIN end:
36.86 KiB
Socket 775 - ASRock 4CoreDual-VSTA, Pentium E6500K, 4GB RAM, Radeon 9500@9700, ESS Solo-1, Win 98/XP
Socket A - ASRock K7S41GX, AMD Athlon XP 3000+, 512MB RAM, GeForce4 Ti4200, SB Live, Win 98
Reply 11 of 18, by bionicle_159
Srandista wrote on 2021-02-07, 21:19:
Here you go:
Male mini DIN:
Female DIN end:
[/quote]
Thanks for finding an archive of the images, shame I didn't see this earlier.
I found a couple more online related to this, including one from an old topic Creative Labs Sound Blaster Live! 5.1 40-Pin Header (cached version = https://lh3.googleusercontent.com/proxy/9PqgW … XODl6EkFtuX85FA) and http://nerdlypleasures.blogspot.com/2010/
Hopefully these links will help if the Vogons images go missing again
Reply 12 of 18, by SScorpio
Here's another link, not that the view of the mini DIN is from the perspective of the Live Drive, so it's flipped from the other images.
https://pinouts.ru/Audio-Video-Hardware/minid … in_pinout.shtml
Reply 13 of 18, by bionicle_159
SScorpio wrote on 2021-02-08, 22:40:
Thanks for helping out!
(I wish there was an upvote option, don't want to spam the forum - this old thread has enough replies from me 🤣)
Reply 14 of 18, by fsmith2003
Has anyone successfully made one of these adapters? Hoping to make one myself but I’m not experienced in what materials I need to buy to make it happen?
Reply 15 of 18, by SScorpio
fsmith2003 wrote on 2021-10-11, 13:48:
You need a 5 pin male mini din, and a 5 pin female din ends, along with at least a three-wire cable. You'll need to solder the wires to the connectors.
I recommend Aliexpress or another site for the cheapest price on the connectors if you don't mind waiting, just be sure to order a few in case you mess anything up. You are working with a small contact points in the mini din plug.
Reply 18 of 18, by aureal
That extra pin shouldnt be a problem because the extra stuff on the male end can be ripped out but I just checked the wiring... it doesnt match up with the midi-mini midi adaptor so it would still require rewiring the cable.
