First post, by SpeedySPCFan
I figure someone around here happens to own one of these things...
I'm currently working on a video talking about the Roland JV, XV, and XP line of synthesizers and have a part where I go into detail about the General MIDI modes on them. As far as I'm aware, these modes SHOULD be identical, but what's making me iffy about assuming that is that the XV synths are actually GM2 compatible and may possibly have their GM1 bank enhanced, with nicer instruments and better mixing as well as supporting features like Reverb and Chorus, which should generally improve sound quality with older games composed on the Sound Canvas and were composed with functions in mind since they do alter the mixing quite a bit.
The main thing is really that mixing and instrument selection though... for those of you who own one of the XV series synthesizers - would you mind recording the two attached MIDI files and sending me copies of the recordings? FLAC is preferable but I don't mind a good MP3 or OGG. I'll give you a shoutout in the video if you want for helping me satisfy my oddly specific curiosity 🤣
EDIT: Huge thanks to Cloudschatze for providing recordings from the XV-5080, I think it's safe to say that Roland fixed all of the issues I had with the older models... if anyone has a 5050 or 2020 to provide recordings of I would appreciate that so I can confidently say that the whole XV range fixes my complaints, but I know at least the 5080 does.
    JV XV MIDI tests.zip
    27.37 KiB
    79 downloads
    Three MIDI files
Musician & music gear/game reviewer.
MIDI hardware: JD-990, SC-55, SC-880, SD-90, VL70-m, Motif ES, Trinity, TS-10, Proteus 2000, XK-6, E6400U
Reply 1 of 24, by Cloudschatze
Here are digital captures from an XV-5080. I'm not sure about the other XV synths, but the 5080 features a "hidden" GS mode, with an instrument set compatible with the SC-50 (SC-55mkII minus the MT-32 tones).
Descent - Level 1
Ys Eternal - First Steps Towards Wars
Ys Eternal - Palace
Reply 2 of 24, by SpeedySPCFan
Well, *this* is why I don't make assumptions about synths anymore... even the basic GM bank sounds miles better than the one on the XP-30 and the JV synths (I've gotten recordings from my friends on their 1080 and they seem identical to my XP-30 and the 1010 uploads on YouTube besides DAC differences). The mixing is better, the instruments are better, pretty much everything is improved. It's very noticeable on Descent and Ys Eternal - First Steps Towards Wars, both of which had drums that were way too loud. I also didn't know about the hidden GS mode, that's pretty awesome.
Thanks a ton dude! You get my eternal respect and a shout out by someone with 1.6k subs 😉 Is there any particular place I should link, or just your YouTube channel and username?
Reply 3 of 24, by Cloudschatze
You'll want to re-download the GS captures. There was an issue with the initial GS Reset not actually being a GS Reset. 😵
Yeah, compared to the JV line, I've always been of the opinion that the XV-5080 replicates the balance and dynamics of the Sound Canvas series to a much greater degree.
I'll pass on the shout-out, but thank-you. 😀
Reply 4 of 24, by SpeedySPCFan
That it does, it seems to be significantly better going by those recordings.
If you say so... if you don't want to be named in the video at all then the part of the video where I go over this stuff will have to be worded something like this:
"(...)at least one of the XV synths, the XV-5080, makes a huge step in the right direction towards fixing this mode if these recordings provided by a friendly forum user are anything to go by."
Though I was planning to cut out the italic'd bit and just say,
"Thanks go to the VOGONS forum user Cloudschatze for making the XV-5080 recordings you just heard and for mentioning the hidden GS mode,"
at the end of the GM mode bit since I feel weird not at least giving you a proper thanks. But if you want to stay totally anonymous that's fine by me too, I just appreciate the recordings so I can make a more accurate and comprehensive video!
Reply 5 of 24, by yawetaG
Search Gearslutz forums for these modules, the subject has been discussed at length by many, many people there (the same really goes for the JV-series). There are differences in the electronic components used in the sound processing and output stages that are responsible for the differences you hear.
Reply 6 of 24, by Cloudschatze
This is a separate discussion, for the most part. There are fundamental differences in the GM implementations/patches between Roland's higher-end product lines, irrespective of the electronic components involved.
There had been a relevant thread on the Quest Studios forum over a decade ago. While that's long gone, the "sound card comparison" page survives on the MIDI Music Adventure Show website, and includes recordings from a JV-1080, XV-5080, and Fantom XR.
http://www.midimusicadventures.com/queststudi … rd-comparisons/
Reply 7 of 24, by BloodyCactus
well 5080 has bigger rom doesnt it? it also is doing 44khz instead of 32khz so it should sound better.
Reply 8 of 24, by Cloudschatze
Certainly, but there's more to it than just higher-quality sound. As mentioned, and in reference to the comparison I'd linked to, the XV-5080 better matches the overall GM playback characteristics of the SC-55 than either the earlier JV-1080 or later Fantom XR.
Reply 9 of 24, by SpeedySPCFan
yawetaG wrote:
(snip)
What Cloud said is accurate - this thread isn't concerning differences with sample rates, DACs and other stuff in that vain (I'm well aware of those) but the implementation of GM mode and how instruments were mapped/mixed.
Huh, I knew about that page before but somehow missed it had JV-1080/XV-5080 comparisons. Those are quite helpful too, thanks!
Reply 10 of 24, by j^aws
Can someone explain what these 'imbalances' are when compared to a Roland SC55? Are we talking volume differences across 16 MIDI channels? If so, you should be able to use a MIDI channel mixer to suit taste.
You're going to get variations across instruments between different tone generators due to samples used and signal path.
Reply 11 of 24, by Cloudschatze
Volume levels/envelopes are a large part of it, but also filter envelopes, effect levels, timbre differences, etc. Outside of the authoring device and direct variants, GM-playback is mostly varying degrees of "close enough," some being more acceptable than others.
Here are a few SC-55mkII and XV-5080 comparisons I'd made with tracks from Quest for Glory IV some twelve years ago. I think the XV-5080 provides interesting, "close enough" renditions. Notwithstanding, I would never play this, or any game for that matter, with the XV-5080.
Meeting With Katrina
Hotel Mordavia
Hexapod Battle
Erana's Garden
Dr. Cranium's Laboratory
Finale
This would be grossly impractical in practice. 😀
It's not really a problem that needs to be solved though, so much as a difference to be noted - GM playback simply varies between higher-end Roland product lines.
Reply 12 of 24, by yawetaG
So instead of being specifically a difference between GM banks, it is likely that for the same patches (no matter the kind of bank) there will always be differences between the XV and JV series, since effects and the like are dependent on the module itself and not specific to the GM bank...
This would be easy to confirm using a SR-JV card expansion card, since they can be used with both some JV series and some XV series modules.
Reply 13 of 24, by j^aws
Thanks for the links. I can hear subtle differences, but both are close. Did you use onboard DACs for both, or route via SPDIF for the XV-5080?
As I mentioned with the signal paths that alter the sound, the DAC would also be part of it, besides filters, effects processor and the sample itself for the instrument.
Why would you say that? You'd feed the MIDI Out to a hardware controller, which then feeds the synthesiser. The controller could have 16 sliders that send MIDI CCs to the target synth to control volume for each of the 16 MIDI channels, for example.
Reply 14 of 24, by SpeedySPCFan
That might work okay for some games but you'd run into issues with anything that uses a lot of volume and/or expression commands.
Reply 15 of 24, by j^aws
Okay, might be worth testing it out one day.
BTW, I've got a Roland XV5050 and tried digging it out, but it's buried in a pile of boxes somewhere, so won't be able to test it anytime soon.
Reply 16 of 24, by yawetaG
Some MIDI mixers can handle multiple CC parameters at once, and can also be controlled from a sequencer for even more fun. See for example the Peavey PC1600.
Furthermore, nothing stops you from using a pedal board MIDI controller for even more realtime control (e.g. Roland FC-300, they still make it).
However, if the effect settings for the GM patches also play a big role in how the GM patches sound, you could also simply tweak the GM bank patches (and save them) to get closer to the real SC-55...
Reply 17 of 24, by Cloudschatze
yawetaG wrote:
Some MIDI mixers can handle multiple CC parameters at once, and can also be controlled from a sequencer for even more fun...Furthermore, nothing stops you from using a pedal board MIDI controller for even more realtime control (e.g. Roland FC-300, they still make it).
Again, this is impractical, especially concerning game playback/usage. You would be endlessly tweaking volume levels on the fly - after Reset/System On messages, and following any subsequent Volume or Expression CCs that many sequences are going to contain throughout.
This type of minor tweaking isn't feasible with any of the synthesizers mentioned in this thread; the GM patches are a black box.
On the XV-5080, for example, the detailed settings for these patches cannot be viewed/edited, nor can a GM patch be copied to a user bank for detailed editing. Worse still, this patch data cannot be extracted out of the temporary patch buffer via any known SysEx - the request is simply ignored when a GM patch is selected. As with the Sound Canvas series, "editing" of the GM patches is limited to a subset of parameters and offsets at each Part level, which are then applicable to any GM instrument that gets selected for that Part, but that's it.
Reply 18 of 24, by j^aws
Okay, I get what you are trying to say, but that makes these mixers unusable. However, my understanding is that these MIDI channels are being given relative volume settings across 16 channels. The Expression volume is a different CC, the note velocity is giving the instrument volume, and then there's the master volume. These volume controls are separate, however, the channel volume CC is a relative volume, rather than an absolute volume. This makes more sense with these mixers.
Reply 19 of 24, by Cloudschatze
Not at all - just unusable in this context.
For sake-of-argument, let's say I'm about to play some Quest for Glory IV. Here's how the volume level (CC#7) of just Part/Channel 10 looks over the first little bit of gameplay:
100 - Default/GS Reset
107 - Sierra Fanfare
107 - Introduction
107 - The Caves
117 - Battle of the Badders
095 - Escaping the Battle
109 - Wyvern Battle
...and so on.
This doesn't even take into account any use of the game's volume slider, which would further throw things off.
Let's say my synthesizer's GM drumkit is too loud in the mix. Using a device that sends CC#7's (or even just the front panel), I could certainly adjust that volume on the fly, but my setting would get overridden by the in-game music data with every track change. Even if a particular MIDI mixing device were to send a set CC#7 value at recurring micro-intervals (neither of mine do), that fixed value would result in further volume issues between tracks.
