First post, by deleted_nk
I'm working on my 775 Xeon based build and have a bit of a question when it comes to the soundblaster cards from around 2007-2010. A lot of them don't appear to support having a front-panel audio jack connected to them, rather they seem to force you to use Creative's 5.25 drivebay for it instead.
Are there any Soundblasters from that time period that support a front panel jack and don't cost the moon? I'm reusing an old Asus Xonar DG but that doesn't do EAX so a soundblaster would be nicer 😀
Reply 3 of 12, by tayyare
I remember buying a cable/adapter to connect Audigy 2 ZS to the front panel connectors. Mine was being advertised as for an Audigy 2 ZS, but there are others, too.
https://www.ebay.com/p/Front-Panel-Audio-Adap … 0670/1776245877
There are some minor issues like not auto muting the external speakers when a headphone is connected to the front panel connectors but it' could be a cheap alternative.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 6 of 12, by Baoran
I still have my old sound blaster X-FI stored. I didn't put it in my main PC when I built it in 2013, but I always wondered how it would compare to the on board audio of Asus Formula VI that the system has. I also don't know if it has standard front panel connector because the small manual that came with it doesn't say anything about that and just concentrates on the optional I/O drive upgrade.
1.81 MiB
Reply 7 of 12, by SirNickity
Yeah, that's exactly the case. THANKS, Obam.... I mean, Creative.
I looked at the pinout once to see about making my own adapter. It's mostly digital I/O, so you have to use an i2s DAC/ADC. You can't just hack up a cable and get analog audio to the front panel. Obnoxious. Every motherboard with cheap onboard audio had the header, but purpose-built sound cards? Noooooo. 😜
Reply 8 of 12, by deleted_nk
Seems as though the Titaniums are one of the cards that force you to use the I/O drive from my research. Similar story to most of the X-Fi cards except for the lower end ones it appears.
Now, I found the Audigy Rx series of cards. They're PCI-E but they've got a audio header on them too. Are these any good compared to the X-Fi cards? They still seem to be made nowadays which is nice
Reply 9 of 12, by appiah4
Some SB Live cards, especially OEM versions, have a white front panel connector for Dell PCs and whatnot but I have, to this day, not been able to figure out what type of connector they use..
Reply 10 of 12, by tayyare
This might help:
https://www.aliexpress.com/store/product/Fron … .9e4514f5Cb2zKp
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 11 of 12, by canthearu
Lol, I hacked into one to get the sound out for the little speaker in one of my acer computers.
https://forums.tomshardware.com/threads/sb-li … o-jacks.257509/
More details here!
Reply 12 of 12, by appiah4
Oh wow thanks to both of you, this will sure be helpful. My main purpose is to route Live! through another sound card, and this will work beautifully.
