Hi all! and especially FreddyV! 😀
It's the new guy with the HP200LX videos again 😀
This is a nifty bit of software, much better than GLX imo...
I tried GLX first (found it online with a google search),
and it worked but was unstable, it would hang/lock up halfway during playback and at other seemingly random moments...
It played the MODS, but there was no display as the interface does'nt support CGA graphics...
Then, I found this thread and I downloaded the latest beta 26, and it's WAY better 😉
I've uploaded 2 videos to youtube of Mod Master playing two 4 track MOD files,
using a parallel port PCMCIA card and a Serdaco CVX4 Covox-clone,
i've attached the links to the youtube videos to this post.
I soldered a 32MHz oscillator crystal in this unit,
so the Hornet SOC's CPU (80186) is running at 16MHz, twice as fast as a stock ~7.91MHz 200LX.
I've got a stable playback of 4 channel MOD files at 28KHz 8-bit mono...
I've tried 30Khz but that's just a tad too much and the audio starts to stutter...
For 8 bit audio, it sounds pretty good, somewhat comparable to regular audio cassettte 😉
It's a real drain on the batteries though, the doublespeed CPU, the optical serial mouse AND
the CVX4 are all powered from the 200LX's main 2 AA batteries,
and with this setup I reckon the batteries drain at 3x to 4x the normal speed...
Anyways, If I load a bunch of MODs on my 200LX, i'll have a "27 year old MP3 player-like device" that fits in your pocket...
(if you have very large pockets that is, with the parallel cable and CVX4 and all 😀 )
Hope you like the videos, I just downloaded a few random MOD files,
if you have any really good ones, please post a link so I can listen 😀
Here are the youtube videos of Mod Master in action!:
https://www.youtube.com/watch?v=mOjwy-1CLC4
Mod Master playing a Drum & Bass mod file I found online on the CVX4...
https://www.youtube.com/watch?v=zJ0IVZ9FOkE
Mod Master playing a techno mod file I found online on the CVX4...
Cheers,
Terrence
FEATURE SUGGESTION!: It would be really handy if you could create a pure monochrome UI option,
with inverted black/white as an additional option, as I've got issues
reading some parts of the text in different colours on the monochrome CGA graphics,
and I have to switch from 2 to 4 greys and invert the display at times to be able to read certain things...
I think this might also be of benefit to many users who use old hercules (with CGA emulation) graphics PCs,
or old portable computers with LCD panels that work inverted or convert the CGA colours to 1 or 2 bit greyscale...
