First post, by mothergoose729
Hey guys, total hi-fi n00b hear, be gentle. A while back I picked up a couple of Roland monitors second hand. They are made for things like digital keyboards and guatair amps and the like, but I would like to use them as PC speakers. They look just like these:
https://images.reverb.com/image/upload/s--5C_ … cf3q2js2eap.jpg
I bought a 3.5mm audio cable that splits into left and right channels of the appropriate size for the monitors and plugged those into the line in jack on the back. If I plug that into my phone and play music I get very decent sound and stereo separation out of both speakers. So I am in business right?
Not so much. I bought a 3.5mm audio extension cable and plugged that into my X-Fi Gamer and Aureal Vortex 2 sound cards. I have also tried plugging them into a KVM swith with 3.5mm. I get tons of noise, usually sounds only comes out of the left speaker, and overall it is all just garbage. If I plug my headphones into the same 3.5mm extension cable I get perfect audio, so I don't think the problem is interference, at least not interference that should matter.
I feel like I need more equipment, but like I said, I have no idea what I am doing when it comes to audio stuff.
1) I want to get rid of the noise and get proper stereo separation
2) I want mono sources to play out of both left and right speakers
3) I would like to be able to split the output so I can toggle between my heaphones and the speakers
4) I don't want to spend that much money if I can avoid it and I don't have a lot of physical space, so something with a small foot print would be great
Would anybody be kind enough to educate me 😵 . Any recommendations on setup and what products I should look for? Thanks!
