sound blaster fatal1ty fps iso
First post, by Robhalfordfan
hi all
i have a sound blaster fatal1ty fps sound card but it didn't come with the discs
i know i can get the driver from the website but i would like to the discs aswell, even if it is iso files
if anyone knows where i find the discs for xp and vista etc or iso files online would be greatly appreciated
Thank you
Reply 1 of 31, by chinny22
I'm asuming thats what the X-FI isos here are for
http://vogonsdrivers.com/index.php?catid=7
The driver CD would be the same for the full range based on that EMU chip. Hopefully these aren't for the EMU20K2 chip!
Reply 3 of 31, by Robhalfordfan
i gave the iso's on here a try and no luck it doesn't detect my sound card with the xp iso and vista iso
Reply 4 of 31, by cyclone3d
What is the PCI ID as seen in device manager for your card?
I have the 2005 X-Fi XP Install CD that I will go ahead and image and upload to vogonsdrivers.
CD ID is:
SBXF-SIS1D-W2-LB
Here it is:
http://www.vogonsdrivers.com/getfile.php?file … menustate=43,36
Edit: This CD looks exactly like the one that came with the Fatal1ty FPS according to a listing I found on eBay.
The CD contents listed on the box also matches what is on this CD. Hopefully it works for you.
If I remember correctly, the .inf file had nothing to do with the setup program being able to detect the card you were installing.
The setup program did all of that. Even if the main install for the CD will not work, you may be able to install the missing apps one by one as I don't think they check for specific cards.
A little bit of history about the Vista support for the X-Fi PCI cards.
Apparently back in the day, Creative did not have working Vista drivers for the X-Fi cards.
At one point they released a CD for Vista that you could order for the price of shipping.
I think the ID of this CD was SBXF-SIVIS-W2-LB.
Once it was out, some people made an ISO and stuck it on various file sharing sites as well as torrent.
Try as I might, I have been unable to find any working links for this ISO.
I was able to find what I think may be a new copy of the Vista X-Fi CD and ordered it along with the X-Fi demo CD.
I'll update this thread once I receive it. If it is different than the XP/Vista CD that is already on vogonsdrivers, I will go ahead and make an ISO and upload it.
Edit: 3,400th post for me.. Woohoo!
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 5 of 31, by Robhalfordfan
ok thanks will give them it a try and i am also looking for vista driver disc aswell since the vista iso on here didnt detect my card either
i will look up pci id for my card when get home and edit this response later on
and fingers crossed when you get them and upload, that they work
Reply 6 of 31, by Robhalfordfan
the 2005 xp drivers disc provided by cyclone3d works in XP and detects my card and installs everything fine
thank you cyclone3d 😀
hopefully the vista drivers will work with my card
the PCI ID, which is it, device instance id, hardware id, compatible id or matching device id
Reply 7 of 31, by cyclone3d
Sweet! Glad to hear it. And people wonder why I don't throw stuff like this out. I knew I had an X-Fi disc. Had to dig through one of my big boxes of CDs to find it.
I think it is the hardware ID, but you could post all of the IDs listed.
The Vista disc was shipped out to me today so it should probably arrive sometime next week.
YMF7x4 Guide
Reply 8 of 31, by Robhalfordfan
ok i can test it for you and see it will work for vista aswell
here is what is listed in device manager for this card
Device Instance ID - PCI\VEN_1102&DEV_0005&SUBSYS_00\4&1A82106&0&5078
Hardware IDs - PCI\VEN_1102&DEV_0005&SUBSYS_00231102&REV_00
- PCI\VEN_1102&DEV_0005&CC_040100
Compatible IDs - PCI\VEN_1102&DEV_0005&REV_00
- PCI\VEN_1102&CC_040100
- PCI\VEN_1102
- PCI\CC_040100
- PCI\CC_0401
Matching Device ID - PCI\VEN_1102&DEV _0005&SUBSYS_00231102
how did you order the drivers disc and demo disc or were they from ebay
Reply 9 of 31, by cyclone3d
Yep, just as a suspected. The drivers from any of those CDs should technically work. It is just the setup program that is being stupid.
I found the Vista installation CD and Demo DVD on Ebay.
YMF7x4 Guide
Reply 11 of 31, by cyclone3d
Just finished uploading the Vista driver CD. It has a different Disc ID and is also newer than the Vista ISO that was already on vogonsdrivers. Also has XP / XP 64 / 2k drivers as well.
http://www.vogonsdrivers.com/getfile.php?file … 583&menustate=0
I'll do the DEMO DVD soon.
YMF7x4 Guide
Reply 12 of 31, by Robhalfordfan
this version for vista doesn't detect my sound card
Reply 13 of 31, by cyclone3d
Hrmmm. That is with running the main setup program, correct?
YMF7x4 Guide
Reply 14 of 31, by Robhalfordfan
yeah the main setup and even try the xp version and thats that vista isn't compatible
think i would to get all "bloatware" with it to try and see use the card to full use
Reply 15 of 31, by cyclone3d
I wonder if there was ever a Vista Installer CD that worked with that card.
I'll have to take a look and see if maybe there is some resource/config file that defines what cards the setup program sees.
YMF7x4 Guide
Reply 17 of 31, by cyclone3d
What happens if you just install the drivers and then go into each application folder on the CD and run the setup programs for each application separately?
YMF7x4 Guide
Reply 19 of 31, by cyclone3d
Yeah.. The Creative autoupdate I am pretty sure no longer works. It was really janky even when it was working.
YMF7x4 Guide
