First post, by ultra_code
Hello VOGONS,
Yesterday, I had the strong desire to play some Halo CE, in anticipation for the re-release of the game in the MCC on PC, and so, I installed the game under XP Pro 64-bit Edition on my i7-3770k machine (the first install of 64-bit XP I have ever done), and while the game runs perfectly, I noticed something when I went to the Audio settings menu, after I had forgot to enable EAX effects (the system has a Creative SoundBlaster X-fi Titanium Fata1ity PCIe sound card, meant just for older games that support EAX under XP). The EAX option was grayed out!
I made sure that EAX was enabled in the sound card's driver menu, and by default it is. I have the latest driver for the card for XP x64:
And, just to make sure Halo wasn't the only culprit, F.E.A.R. too has the same issue:
So, I'm confused as to what is happening. Are the Creative drivers kinda broke under x64 (doubt this myself)? Does EAX support only work under 32-bit OSes (I had no issue enabling EAX under 32-bit XP)? Is there some additional configuration I need to do to properly enable EAX support globally for all games, or do I have to do something on a per-game basis? I'd love to get this issue resolved, and hopefully get that slightly-better-than-stereo speaker experience whenever I boot up this rig once a month. 😜
Any help would be appreciated.
Builds
Reply 1 of 18, by derSammler
Windows XP x64 is actually Windows Server 2003 at its core and has not much in common with Windows XP x86, apart from the same GUI. The game(s) may simply not detect that they are running on an EAX-capable Windows XP (which - to some extent - is correct).
Reply 2 of 18, by ultra_code
derSammler wrote on 2020-02-26, 20:17:
Yeah, I heard that XP x64 has a newer kernel than x86 XP. Still... would that really be enough to make games think there isn't EAX-capable hardware when there is?
Builds
Reply 3 of 18, by cyclone3d
I don't remember having this problem back when I was running XP x64 when it was current.
I would have probably had a Sound Blaster Audigy of some sort back then though.
Have you tried setting the games to run in compatibility mode?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 18, by ultra_code
cyclone3d wrote on 2020-02-26, 22:57:
I've never thought of doing that before under XP with an XP game, but I attempted it, and nothing:
Also, the longer I play Halo CE, the more buggy I find the game to be than I ever remembered it to be (then again, I only really remember playing it for real as a child, and the rest of the times it was the updated MCC edition on the Xbox One). And I patched it with the latest official patch - 1.0.10. I've limited the game to using one CPU thread to help, because I know older XP games look at a 4-core, 8-threaded CPU and not know how to best handle all of the resources it's give, but that only does so much.
I guess I could reinstall the sound card drivers, but I seriously doubt that would solve the issue. Reinstalling the game might help, but even if it did solve the problem, a) we wouldn't know what exactly caused it to begin with, and b) that would still leave F.E.A.R.'s identical issue in question.
Again, I'm confused.
Builds
Reply 5 of 18, by swaaye
https://danielkawakami.blogspot.com/2017/01/s … ack-62.html?m=1
There is no DirectSound hardware acceleration on Windows XP 64-bit (x64) with 4GB RAM or more […]
The Audigy driver does not support 64-bit addressing, disabling the DirectSound hardware acceleration and causing multichannel sound to be played only in the stereo channels (front left/right).
Workarounds:
- install the 32-bit (x86) version of Windows XP.
- limit to less than 4GB the amount of RAM available to Windows.
- enable the "Memory Hole" setting in the BIOS Setup, if your motherboard supports it.
- install and use Creative ALchemy to convert the DirectSound API calls into OpenAL, which is not affected by this issue.
I think that sums it up. I remember reading this at some point. So give those workarounds a try. Alchemy on XP! Heh.
I wonder if DSOAL works on XP x64.....
Reply 6 of 18, by DosFreak
Have you tried modifying config.txt?
https://opencarnage.net/index.php?/topic/7383 … dated-05092019/
You can also try running the game with Dependency Walker to see if you are missing any files.
You can also try the EAX wrappers like Alchemy, DSOAL, indirectsound etc.
https://forums.ubisoft.com/showthread.php/225 … P-64-Bit-Forums
You can quickly test limiting the memory using msconfig
You can run through all the various driver versions, according to the below thread the modified driver worked to enable EAX on XP 64bit. Don't know if you can track that one down. If not them possibly a driver version later than the one you have may have fixed the issue:
https://web.archive.org/web/20080625113006/ht … php?t27037.html
https://www.overclockers.com/forums/showthrea … 369#post5299369
Make your games work offline
Reply 7 of 18, by ultra_code
DosFreak wrote on 2020-02-27, 02:27:
Have you tried modifying config.txt? https://opencarnage.net/index.php?/topic/7383 … dated-05092019/ […]
swaaye wrote on 2020-02-27, 02:17:
https://danielkawakami.blogspot.com/2017/01/s … ack-62.html?m=1 […]
Workarounds:
Jesus, that's a lot of info to take in. Thank you guys so much! I think I'll be able to find a solution in all of that, especially that forum post page, but you are going to have to give me some time. I'll spend a good few hours on this on the weekend.
Builds
Reply 8 of 18, by ultra_code
So... I found the solution.
So, I first I went to see if my BIOS supported that "Memory Hole" feature, @swaaye, and in fact it did and was already enabled. Toggling it did nothing.
Then I added "support" for my GPU and sound card into the config.txt for Halo, as per the forum post's suggestion, @DosFreak. That... did nothing. It allowed for the game to properly name the GPU at least, but nothing else really.
Then I finished my first Legendary playthrough of the game. 😁
Then I tried dumping DSOAL's DLLs into the root directory of the game. Nothing. In fact, it essentially disabled sound for the game.
Then I tried installing different releases of Creative Alchemy. Nothing, as the installer complained it wanted Vista+.
Finally, I limited the memory XP could use to 4GB, which it then automatically so graciously rounded-down to 3.5GB, as that is the relative limit for the amount of system RAM 32-bit versions of Windows can handle.
And, that did the job surprisingly. No need to mess with anything else. Although, it's kinda sad that's what it takes for EAX to work. I would'a thought at this point, maybe someone came up with a patch to the Creative drivers to solve this issue at this point.
@Cyclone3D, when you were running XP x64 "when it was current," how much RAM did you have in your machine? My guess is you had 4GB or less, no?
Builds
Reply 10 of 18, by DosFreak
It would be nice if we could track down the modified drivers that allow EAX with >4GB of memory.
Until then instead of limiting the memory would EAX still work if a ram drive was used instead?
Then mabye could enable or disable as needed without a reboot.
http://www.ltr-data.se/opencode.html/#ImDisk
Reply 11 of 18, by mastergamma12
Well, this explains why my Titanium Fatal1ty Champ (at the time) in my xp machine didn't want to work with eax on xp 64........
Reply 12 of 18, by ultra_code
mastergamma12 wrote on 2020-03-01, 23:47:
The More You Know TM
Builds
Reply 14 of 18, by aaron158
IMO ud be better off to just install x86 xp having more then the 3 some odd gigs x86 will let u have is pretty much pointless unless u get into games from 2007 or 8 and beyond and those games would run better under windows 7 anyway.
i would say games from 2002-3 upto 2007ish are perfect for xp x86 games beyond 2008 go windows 7 x64.
Reply 15 of 18, by Schule04
mirh wrote on 2022-01-25, 21:24:
Reference for this behaviour
https://web.archive.org/web/20091022130117/ht … y/ms790402.aspx
Also interesting to note Windows 2000 64-bit lacks hardware acceleration, while Windows Server 2003 has it.
Not that surprising, Win2000 64bit is for Itanium only and lacks many other things as well IIRC
Reply 16 of 18, by mirh
Ok, actually according to tidbits from 17 years ago.. This isn't even necessarily about the operating system per se, but just the drivers?
Because of course creative had to botch them.
As for dsoal, of course it was failing just like it wouldn't run on the 32-bit version either. You want dsoal-xp if any, for as much as currently unmaintained (confirmed to be working in the issues).
pcgamingwiki.com
Reply 17 of 18, by LSS10999
mirh wrote on 2024-06-24, 15:21:
... I think Creative had a lot of issues back then. Some of which only manifested when system memory became more available (>=4GB), and some of which also affected x64.
I remembered having issues with mic and some other stuffs with Audigy 4 on a Win7 x64 system with 4GB RAM and there was a suggested registry tweak back then. However, that only resolved the issue with 4GB RAM but not any higher as far as I could remember.
On the other hand, Creative had a critical design flaw back with SBLive!, which totally borked its hardware MIDI synths if you have more than 2GB of RAM. It doesn't matter whether you use Creative's official drivers, or kX.
X-Fi appeared to have corrected those hardware design flaws but driver software was no better. On a PAE-enabled WinXP its driver could BSOD at random or specific occasions, and sometimes the driver could outright fail and hang the system (on driver load, either during boot or during install) in a very strange manner -- when it hangs, even RESET button would stop working and I have to power cycle. Because of that I'm only using that sound card for Win7 for the time being...
PS: Is there a ready-to-use dsoal-xp build that I could experiment with WinXP? (EDIT: Pre-built binaries exist in the "release" folder... though I'll have to test it myself to see if it really works...)
Reply 18 of 18, by UCyborg
I recently got my hands on an Audigy Rx and got the same problem. I installed latest Audigy Support Pack 8.1 by Daniel Kawakami and did the /MAXMEM=4096 trick, but hardware acceleration is still unavailable.
I can't tell what's different about my system. Any idea how to troubleshoot?
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
