First post, by odd144
Hello,
Bought a Sound Blaster Live!5.1 card, working well in Windows 98SE.
Dos is a slight struggle, I am using the Livedos drivers from PHILs Computer Lab (https://www.philscomputerlab.com/sound-blaster-live.html). In DOS I can get most games working however for a few games, Syndicate/Space Quest 1 VGA, it gives a “DOS/4GW Fatal Error: Transfer Stack overflow -- , Microsoft Corp”
Not sure what is going on, any idea how I can fix this?
I access DOS by editing MSDOS.SYS to have "BootGUI=0" command and restart the PC.
Config.sys:
DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\WINDOWS\EMM386.EXE RAM I=B000-B7FF AUTO
DEVICE=C:\WINDOWS\IFSHLP.SYS
DOS=HIGH,UMB
REM ** FILES=30
BUFFERS=20,0
LASTDRIVE=Z
DEVICEHIGH=C:\DRIVERS\VIDECDD.SYS /D:OPTICAL
FCBS=4,0
FILES=60
Autoexec.bat:
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /E /D:OPTICAL
LH C:\DRIVERS\CTMOUSE.EXE /R2
@ECHO OFF
PROMPT $p$g
PATH C:\WINDOWS
SET TEMP=C:\WINDOWS
Any help is greatly appreciated, thank you.
Reply 5 of 6, by odd144
boxpressed wrote on 2020-03-05, 04:59:
Try booting with a DOS 6.2x bootdisk instead of Windows 98's DOS 7.1.
Trying to do so and I used a bootdisk from this site for "https://www.bootdisk.com/bootdisk.htm" for MS-DOS 6.22 however when it boots it doesnt give me access to my C: drive only A:?
Thanks
Edit: Tried Windows 95 bootdisk, it gave me the C: drive however same issue "Stack overflow" in Syndicate 🙁. Did Win95 also come with DOS 7.1?
Reply 6 of 6, by odd144
odd144 wrote on 2020-03-06, 23:44:
Trying to do so and I used a bootdisk from this site for "https://www.bootdisk.com/bootdisk.htm" for MS-DOS 6.22 however when it […]
Thanks
Can confirm it was definitely because C: drive wasn't FAT32.
I used Partition Magic to convert to plain FAT, loaded up 6.22 via boot disk and it worked, could see C: drive!
Win98 wouldn't boot though but went into XP(Dual boot) and coverted it back to FAT32, it worked, everything back to normal!
Ok did this fix the "Stack Overflow issue"? No this did not fix the issue 🙁
