First post, by odd144
Hello,
Bought a Sound Blaster Live!5.1 card, working well in Windows 98SE.
Dos is a slight struggle, I am using the Livedos drivers from PHILs Computer Lab (https://www.philscomputerlab.com/sound-blaster-live.html). In DOS I can get most games working however for a few games, Syndicate/Space Quest 1 VGA, it gives a “DOS/4GW Fatal Error: Transfer Stack overflow -- , Microsoft Corp”
Not sure what is going on, any idea how I can fix this?
I access DOS by editing MSDOS.SYS to have "BootGUI=0" command and restart the PC.
Config.sys:
DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\WINDOWS\EMM386.EXE RAM I=B000-B7FF AUTO
DEVICE=C:\WINDOWS\IFSHLP.SYS
DOS=HIGH,UMB
REM ** FILES=30
BUFFERS=20,0
LASTDRIVE=Z
DEVICEHIGH=C:\DRIVERS\VIDECDD.SYS /D:OPTICAL
FCBS=4,0
FILES=60
Autoexec.bat:
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /E /D:OPTICAL
LH C:\DRIVERS\CTMOUSE.EXE /R2
@ECHO OFF
PROMPT $p$g
PATH C:\WINDOWS
SET TEMP=C:\WINDOWS
Any help is greatly appreciated, thank you.
