New Waveblaster card : Reptile Paradise - Yucatan FX
Reply 80 of 98, by jaZz_KCS
640K!enough wrote on 2020-07-19, 21:45:
With all the talk of this Dream bank being directly derived from the Sound Canvas sound set, I am curious. There is one file that I have noticed only sounds the way it should on Roland devices (among brands in common use with 90s PCs), so if anyone with access to a prototype would be willing to give the attached file a try, we will find out if it's as close to Roland's implementation as some (even old magazines) have claimed.
It is worth noting that I have no Yamaha devices to try, so they may get the right sound out of it too. The X2 with its default bank is among those that do not. There are no tricks or obscure features in use here; just particular instruments in the Roland map that many other cards left out altogether or recorded differently.
EDIT: Fixed the sloppy attachment. I also wanted to mention that the file does play on most devices; it's just missing instruments, producing sub-optimal sound.
I would be interested to hear this through Yamaha XG as well as the aforementioned in Roland mode. I shall test this.
Reply 82 of 98, by keropi
ahyeadude wrote on 2020-08-30, 19:40:
Just bought one on serdashop! This will work with the CHiLL external waveblaster interface right? Want to leave the X2 on my YMF-719 and I'm not sure this would fit there anyway.
yes it works perfectly fine with the CHiLL board!
🎵Link to buy a PCMIDI mpu
🎧Orpheus soundcard project
💻WTB Amstrad PC7486SLC-33 system
Reply 84 of 98, by HandOfFate
I got mine today and it sounds really good.
I tried a whole slew of games with different styles of music (Doom (2), Rise of the Triad, Descent, Theme Hospital, Colonization, UFO: Enemy Unknown, Transport Tycoon, Duke Nukem 3D and SimCity 2000) and I really liked how everything sounds.
My ears aren't tuned enough to recognize sounds from other MIDI modules but I think that (some? most?) instruments are quite different from a SC-55/SC-88. I should make recordings and compare 😀
Am486 DX4 120MHz, no L2, 16MB, Tseng ET4000/W32 1MB VLB, ESS ES1869 + Yucatan FX /// 5x86 133MHz, 256kb L2, 64MB, S3 Virge/DX 4MB PCI, SB16 /// Pentium III 1GHz, 512MB, Asus V7700 64MB AGP, SB Live!
Reply 85 of 98, by Salient
I received mine as well and I love it!
Reply 89 of 98, by appiah4
kisscool wrote on 2020-09-18, 19:54:
Received mine yesterday, as well as the Crystal Blaster C1. Both sound amazing. Serdaco did a great job again 😀
I am probably going to order one or the other myself but I can't seem to decide 🤣.
Reply 90 of 98, by keropi
now that the Yucatan is out there let's not forget Tiido's distortion fix - a small program to lower output volume so there is no sound clipping: Dream SAM9733 and SAM9407 based MIDI devices distortion fix
I think it's a must to have on autoexec.bat if your system has a Yucatan/Cancun/Diamond GS daughterboard
Reply 91 of 98, by darry
keropi wrote on 2020-09-24, 17:36:
+1 to that .
I use a Dreamblaster X2 now, so I no longer have that issue, but when I had a Monster MIDI, it would hopelessly distort without Tiido's distortion fix to tame it and I had it installed on an a card meant for the already loud DB60XG .
EDIT : The fix is supposed to address clipping in the digital domain, before the daughterboard's DAC, however, in my case I was getting clipping at ADC on my soundcard's line-in (to which waveblester connector is wired) and I had no way to attenuate the signal in the analogue domain before it reached the ADC .
Reply 92 of 98, by dreamblaster
The new Yucatan Fx batch arrived, i will start preparing packets this weekend
OPL2LPT, OPL3LPT, X2, S2, S2P, MCE2VGA, ... many projects !
Special vogons LPT bundle : https://www.serdashop.com/Parallel-port-retro-sound-bundle
Thanks for your support !
Reply 94 of 98, by dreamblaster
Nitroraptor53 wrote on 2020-10-09, 21:50:
https://www.serdashop.com/Yucatan-FX So I can preorder it? Awesome
Yes, now you can simply order at https://www.serdashop.com/Yucatan-FX
I have stock and can ship ASAP. So it is no longer pre-order, but order.
Reply 96 of 98, by dreamblaster
Yucatan Fx production !
Reply 97 of 98, by DosWorld
I just receive notification from Serda - package is shipped. Cant wait!
PS: This adapter will work with Yucatan FX ?
https://www.serdashop.com/CHiLLandPhilAdapter
Also, is available way connect it via LPT ?
CPU: Amd K6/450, RAM: 256M, VIDEO: S3Trio V+, SOUND: EWS64XXL/64M
CPU: iP/100, RAM: 16M, VIDEO: S3Trio V+, SOUND: SB AWE32
IBM Aptiva, CPU i486DX/80, RAM: 96M
Compaq Contura 4/25 2820D, CPU: i486SX/25, RAM: 4M, VGA.
HP 200LX/2M
Reply 98 of 98, by dreamblaster
DosWorld wrote on 2020-10-10, 13:11:
PS: This adapter will work with Yucatan FX ? https://www.serdashop.com/CHiLLandPhilAdapter
No, it will not work with chill n phil. Yucatan FX needs the +12V, and chill n phil only has 5V.
It works fine with the larger CHiLL adapter : https://www.serdashop.com/CHiLL
No
