First post, by PlaneVuki
Looking for ms-dos driver for this PCI sound card.
Anyone has? Anyone knows?
Thanks in advance.
I attached the photo:
    1.23 MiB
Reply 1 of 18, by cyclone3d
Have you checked the Install CD?
https://archive.org/details/CS4281DriverCD
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 18, by darry
PlaneVuki wrote on 2020-06-08, 21:29:
I now checked them, but neither the CD nor the website have driver for DOS.
I beg to differ . Windows 95/98 drivers come with the cwrdos.exe DOS initialization utility . What more do you want/need ?
EDIT: I attached the zip file to this post .
Pv5018.zip
240 KiB
286 downloads
Reply 6 of 18, by darry
PlaneVuki wrote on 2020-06-08, 22:36:
So, win95/98 drivers will also work in dos? Sorry I am not very knowledged about sound stuff. Thanks for the zip file. I will try it on my machine and get back with the results.
Not exactly.
Usually DOS utilities/drivers were included with the Windows 9x driver pack, but they usually can function independantly .
Reply 7 of 18, by PlaneVuki
When I run cwrdos.exe it gives "Error loading dos configuration file" error and quits. (I tried your zip and the CD, same result)
What is wrong ?
I did a fresh dos install, clean, doom and quake tested, work good.
    106.16 KiB
Reply 8 of 18, by darry
PlaneVuki wrote on 2020-06-09, 17:39:
What is wrong ?
Ah, yes, sorry. This is one of those braindead situations where you actually need to install the Windows 9x driver for it to generate that config file c:\windows\cwraudio.wcm .
If you don't want to keep Windows, you can then backup the file, wipe Windows (format if you like), recreate a windows directory and put the cwraudio.wcm file in it . Cwrdos.exe should still work .
See this forum post for info (use google translate if necessary).
http://www.dosforum.de/viewtopic.php?t=7100
Reply 11 of 18, by PlaneVuki
Hello darry,
On one of my pentium machines it works good, but:
On my other pentium machine it sets irq to 15, port and dma are correct.
* Found PCI BIOS
* Initializing the VCPI interface
* Found a CS4281 Revision C
* Initializing CS4281
* Blaster using Port: 220 Irq: 15 Dma: 1
* Uninitializing the VCPI interface
* Could not find winbootdir enviroment varabiable
* Terminating and staying resident
(with the above settings, music works, but SFX don't)
How can make it to load the driver with the settings that I want?
Of course mostly it must be port220 irq5 dma1
Reply 12 of 18, by darry
PlaneVuki wrote on 2020-06-20, 17:28:
Hello darry, […]
Hello darry,
* Found PCI BIOS
I would try reserving the IRQ you want to use for legacy use in the BIOS .
Reply 13 of 18, by PlaneVuki
darry wrote on 2020-06-20, 17:37:
Hello darry, […]
Hello darry,
* Found PCI BIOS
I tried that just now, in my bios in this format:
IRQ X used by ISA : YES/NO (can be set to either YES or NO) where X is: 3, 4, 5, 7, 9, 10, 11, 12, 15
I tried some combinations with no luck:
* leaving only 5 as YES
* leaving only 3-7 as YES
* all YES
* all NO
* leaving only 15 as YES
* leaving only 15 as NO
whatever I tried it always sets irq to 15 when I load the driver.
I don't know how to pass parameters to make it set irq to 5 ?
something like: cwrdos /a 220 /i5 /d1 /v (doesn't work)
Reply 14 of 18, by darry
PlaneVuki wrote on 2020-06-20, 17:52:
I tried that just now, in my bios in this format: […]
Hello darry, […]
Hello darry,
* Found PCI BIOS
* all YES
* all NO
Are you re-using the config file created on the other PC ? That may not work . You may need to install Windows and the Windows driver to generate a new config file for this PC .
Reply 15 of 18, by PlaneVuki
darry wrote on 2020-06-20, 21:57:
* all YES
* all NO
I was re-using a config file I found on internet, and it worked on one of my pentium system, but not this one. Ok, that may work. I will try it like you said and get back with the result.
Reply 16 of 18, by darry
PlaneVuki wrote on 2020-06-20, 22:27:
* all YES
* all NO
I am not sure, but I think the config file will reflect the settings used in Windows to configure the legacy device , so you may need to change those if needed . I am far from certain, however .
Good luck.
Reply 18 of 18, by darry
MAZter wrote on 2020-06-21, 02:54:
CS4281 is not compatible with native Dos, no chances to make it works for SFX.
And reason is not IRQ. In my Thinkpad, IRQ is 5 and it still doesn't make it work.
It may not work for you with your Thinkpad and its implementation of the CS4281, but it definitely works for others . It works on the first computer on which the OP tried it . There are also multiple accounts of it working for others on the Internet .
EDIT : The datasheet even says so :
Full DOS Games Compatibility via PC/PCI, DDMA,
and CrystalClear Legacy Support
http://pdf.datasheetcatalog.com/datasheet/Cir … gic/mXyzsss.pdf
