First post, by darry
I just recently ordered a DreamBlaster X2 and my intent is to use it as a waveblaster daughterboard.
However, according to the manual, all preset configuration and soundbank loading is done over a USB connection .
This leads me to the following questions about leaving the DreamBlaster X2 in its waveblaster socket on the sound card and have it simultaneously connected via USB on the same PC while said PC is powered on :
a) Is it dangerous for the X2 to be simultaneously plugged in via waveblaster connector AND USB to a PC while the said PC is powered on ?
b) Assuming a is safe, will the DreamBlaster X2 repond to MIDI data via the waveblaster connector while it is connected to a PC via USB ?
