First post, by IlhanK
I've got a SB0220 in my Win98SE machine.
So far I've found the following drivers to work properly and load soundfonts with my sound card:
- VxD - 4.12.01.0248
- VxD - 4.12.01.0308
- WDM-5.12.01.0252
- WDM-5.12.01.0296 (currently installed)
I especially like the cards ability to use soundfonts with DOS games like Duke3D within "windowed" DOS mode.
To increase compatibility with older titles I am trying to set up an additional CT4520 AWE64.
Which is cool and all, but then I'm loosing the ability to use Soundfonts for DOS games since the AWE64 takes over all signals sent to port 330.
In Windows the SB0220's MIDI devices are mapped to port EF40 which cannot be selected by DOS Games.
It seems that the AWE64 completely disables the built-in SB-Emulation of the Live! Card which is not a big loss. But the loss of Soundfonts for DOS games bugs me.
For testing purposes I removed the SB0220 and replaced it with a ES1373-based SB PCI. With the AWE64 and the SB PCI I can map their MIDI outputs to different ports, 330 and 340 respectively, which allows me to choose the wished MIDI device for DOS games. That works great.
Not much luck with an AWE/Live! pairing though. I am not finding any method to route Live! Soundfonts to DOS games as long as the AWE is installed.
So basically what I would like to do is to keep the AWE64 in the system but not loose Soundfonts for DOS-based games.
Before I waste more time in vain on that I'd like to ask if it's even possible. Has anyone got it to work?
Thanks in advance. 😉
