help with soundcard
First post, by scroeffie
i have a mistumi soundcard with the cd rom drive 1 speed
and also a soundblaster 16 ,the cdrom card has the cd audio cable hookt to the cd rom drive
but how do i get cd audio to the soundblaster 16 card ,do i buy 4 speakers that makes no sense
the cd rom isa card also has audio output ?!
it just makes no sense
and where to find the drivers for the mustmui cd rom drive 1x speed
Reply 1 of 41, by cyclone3d
What is at the other end of the audio cable that is plugged into the Mitsumi card?
Looks to me like there are two cables and one should go to the CD-ROM drive and the other to the sound card.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 41, by scroeffie
thats makes sense to me what you said the audio cable is going from the sounblaster card to the cd rom drive ,but than whats the point of the cd rom isa card ?
because when i got the pc the cd rom cable was going from the cd rom isa card to the cd rom drive !
Reply 3 of 41, by Jorpho
scroeffie wrote on 2020-12-01, 18:26:
Because back then some people wanted to have a CD-ROM without also needing a sound card?
Reply 5 of 41, by Grzyb
The CD-ROM controller interface on CT1740 is for Panasonic/Creative drives, not for Mitsumi.
The analog audio input, however, should also work with a Mitsumi drive - but make sure to check the pinouts, as a different cable may be necessary.
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 6 of 41, by scroeffie
oke i installed the soundblaster driver and the soundcard is working perfect ,i also installed the mitsumi cd rom driver but it wont work i think there is a conflict !?
not shure what to do ,how do i solve this
Reply 7 of 41, by scroeffie
Reply 9 of 41, by scroeffie
no the mistumi cd rom drive has its own controller card witch is plugged in i installed the drivers with succes but it wont give me a letter ,i think there is a conflict with the sounblaster thats as far as i get
Reply 10 of 41, by cyclone3d
Looks like you are using DMA 5 for both the CD-ROM controller and for the sound card.
YMF7x4 Guide
Reply 12 of 41, by cyclone3d
scroeffie wrote on 2020-12-09, 22:36:
so the dma switch on the controller needs to be off or on ?
The CD controller card looks like the DMA jumper is set to 7 which should be fine. Guessing you need some command line switch for the controller driver to specify DMA 7... maybe DMA 5 is default.
YMF7x4 Guide
Reply 14 of 41, by cyclone3d
Well, can you list what exactly is in your config.sys file?
YMF7x4 Guide
Reply 15 of 41, by scroeffie
dont know where to find this file 😀 its this i think ?
Reply 16 of 41, by scroeffie
any one can help me figure this out
Reply 19 of 41, by scroeffie
the software says channel but the card has no channels !?!?
i changed the jumpers and now i got this stil not working i think !?!?
