First post, by Nitroraptor53
- Member
How do I get PCEM to work with Falcosoft MIDI player? Help is much appreciated
You'll need a software MIDI bridge like loopMIDI to get the MIDI data from PCem to FSMP.
Kamerat wrote on 2021-01-07, 02:19:You'll need a software MIDI bridge like loopMIDI to get the MIDI data from PCem to FSMP.
How does that work?
Nitroraptor53 wrote on 2021-01-07, 22:30:How does that work?
Install and run loopMIDI. Use the "loopMIDI Port" as the MIDI out device for your sound card in PCem and "loopMIDI Port" as the MIDI in device in FSMP.
Ok, thanks!
