First post, by MT32!
Does anyone have a file they could share?
Reply 1 of 10, by appiah4
Do a search for Snark Barker on Google, that project has one on the github page.
Reply 2 of 10, by MT32!
appiah4 wrote on 2021-04-26, 06:20:
Those volume knobs are not the correct size. I am having a hard time believing no one has made this
Reply 3 of 10, by appiah4
MT32! wrote on 2021-04-27, 04:25:
Those knobs are the exact correct size for a SB 1.5
Reply 4 of 10, by Thermalwrong
The .zip file attached in this thread seems to be the right size for a CT1740 / CT1600, I haven't seen it uploaded anywhere else: Re: Anyone make a 3d printed volume wheel for the older sound blaster cards yet?
Reply 5 of 10, by MT32!
Thermalwrong wrote on 2021-04-27, 10:13:
tried it but will not work because the back side is not the same where it attaches to the pot.
Reply 6 of 10, by Thermalwrong
okay, I'll make a model of the wheel from my CT1600 and post it up on thingiverse. I see what you mean I think, the underside is inset where the pot fits and the wheel sits over it somewhat when it's installed, instead of just on top of it.
Reply 7 of 10, by MT32!
Thermalwrong wrote on 2021-04-28, 10:23:
Thank would be awesome !
Thanks alot will print it right away
Reply 8 of 10, by Thermalwrong
Here's a version that I've modified to fit the CT1600 / CT1740, it turns out the potentiometer has a slightly larger cam at the top compared to the CT1320.
My CT1600 has a 5mm/4.5mm x m1.6 screw in there, which works with this design too.
55.52 KiB
I hope it works for you 😀
My test prints are printed at 0.1mm layer height using PETG with the 0.4mm nozzle, so you can print this without any special settings or smaller nozzle.
Reply 9 of 10, by MT32!
Thermalwrong wrote on 2021-04-29, 22:54:
Here's a version that I've modified to fit the CT1600 / CT1740, it turns out the potentiometer has a slightly larger cam at the […]
thanks printing it now will let you know , looks like it should work
Reply 10 of 10, by MT32!
worked thanks!
