Reply 40 of 178, by Salient
- Member
arthur071169 wrote on 2021-06-28, 10:51:I am having major issues getting my pi to work with the MT32 software.
First, are you using a suitable PSU, with sufficient capacity?
The microSD card must be formatted as FAT32 and the MT32-Pi build should just be copied over to that empty micro SD card.
For when you are going to use the HAT:
Make sure you set up your mt32-pi.cfg file correctly.
I think in this thread there is a link, but here is one that should work.
Just overwrite the existing file. Note: this is a config for 0.10.0 so make sure you use that version.
Note that you must then use the 3.5mm jack output of the HAT instead of the one on the Pi itself.
