darry wrote on 2021-06-14, 08:59:Thank you! It must have taken quite a while to test and compile. […]
arncht wrote on 2021-06-14, 06:30:
a measured a couple of old isa sound cards in dos with rmaa 5.5.
i used an analog/digital allen & heath mixer for recording, and every output level calibrated to the same input level.
https://drive.google.com/drive/folders/1_aWLW … C-N?usp=sharing
On first glance, it is particularly intriguing to me that the GUS 3.74's amp out actually seems to have significantly better performance through its amp out than its line-out. That and its frequency roll-off .
EDIT: Shouldn't the dynamic range of the 8-bit cards have a hard limit of 48dB ?
you are welcome.
i used a mixer and there is the possibility to calibrate the input level, i set the amplified and the line out to the same level - so probably the background noise is bigger, than how worse is the amp on the soundcard.
i expected worse thd, but i could not see too much disadvantage. by my ears, i always heard the amplified output slightly better.
it could be a biggest problem with a nonstandard hifi input/output, than with a studio equipment.
rmaa55 does not really support 8 bit well, especially 44khz mono, 22khz stereo, etc. so finally after many tests on the recording side, i kept the default 16bit 44khz setting. it is ok for the comparison.
