First post, by matze79
As i still have no Stereo on 1 Device i started with this Design.
This is based on Schematic from Crystal Dreams Demo,
i wanted to avoid using special Parts so it uses discrete R2R Ladder on 2 Latches instead of AD7528.
Channels are switched trough Strobe using a Inverter.
The attachment lptsnd.jpg is no longer available
For now i tested some Software
Crystal Dreams 1&2
Megaplay and Inertia Player
There still some small things that need fixing but after that it would be ready.
Reply 1 of 7, by weedeewee
Cool.
I remember seeing a schematic for the same idea that used two ferranti zn428e chips. unfortunately at the time, early nineties, the chips were already unobtainable for poor young me.
Do not ask Why !
Reply 3 of 7, by ultramars
Interesting device. What kind of drivers does it need to play stereo? Does it appear as two separate Covox Speech Thing to the software?
I suppose data for left & right are interleaved, so that playing 2x 22050khz signals must require to drive the parallel port @ 44100 for example, which means like 386 processor / 2MB memory minimum hardware requirements...
Reply 4 of 7, by FreddyV
ultramars wrote on 2022-04-06, 01:12:
To send data to a Covox, only one "OUT" instruction is needed.
So, Two covox are Two OUT to Two different LPT Port.
Here, we need:
One OUT for Left
One OUT to switch to right
One OUt to Right
Then One Out to go back to Left
It is totally different 😀
I did not add it to Mod Master as I don't have one.
Reply 5 of 7, by matze79
Next Hardware Revision will:
- omit Switch
- Automatic Detection of Playback / Mono / Stereo / Support Different play methods for Stereo Mode (IPlay / Crystal Dreams etc.)
- up to 32Khz per Channel in Stereo
- up to 64Khz Mono
The attachment lptsnd_x2_r2.jpg is no longer available
Reply 6 of 7, by ultramars
it's great to be able to play stéréo covox without the need of two parallel ports, but i still don't understand which software can make use of this device :p
Can this be used with fast tracker for example, since it can drive 2 x covox, or is it only working with certain games?
Reply 7 of 7, by matze79
it works with all sorts of Covox Software. Except Dual LPT Port Stereo Mode.
There is a lot of Software Supporting Stereo on 1.
This Supports multiple methods of Stereo on 1 Playback.
