First post, by smullyoz
Which one of these would be best for win98? From i read both are sound blaster live cards, but the SB0220 is Dell OEM.
Should i just go for the CT4830 in that case and avoid the dell?
Reply 2 of 6, by Gmlb256
pc-sound-legacy wrote on 2021-10-11, 18:19:
As far as I know, both are fine and "true" SB lives. Beware of the SB0200, the earlier Dell OEM live - this is the one with no EAX acceleration in hardware.
This.
However I've heard that the SB0220 needs specific drivers on Windows 9x. Alternatively the Audigy2 ZS drivers works for both cards using a trick done by Joseph_Joestar on the following link: Using Audigy drivers with a Sound Blaster Live.
One has to make sure that VXD drivers are installed, not the WDM ones due to performance and stability problems.
Reply 5 of 6, by Gmlb256
fxgogo wrote on 2021-10-13, 06:12:
I have the CD for the 4830 if you would like the drivers that came with the card. Just used it on a 98 machine and seems to be working well.
There is no need to do that as it's already on VOGONS drivers.
