First post, by crazii
I've read some basics about FM synth and MIDI here: What's the difference between “FM synthesis” and “MIDI synthesis”?
I'm not quite familiar with this, maybe I'm totally talking about bullshit but I hope this is doable:
Background:
Win98 with WDM driver (especially AC97) has SB emulation and General MIDI MPU-401 synth, that works for late DOS games like Warcraft2, Doom. But old DOS games don't have GM MPU-401 driver or no sound driver setup, but only FM synth driver, i.e. Skyroads.
So now I wonder if it is possible to write a win98 driver to capture the register instruction & Music data from SB/Adlib port (i.e. default 220, 388 etc) and redirect it to win98's GM MPU401?
It is not a soft FM synthesizer, just a protocol translation software.
If it could be done, it will make a huge difference, I think.🤣
Toshiba Satellite Pro 4300 - Yamaha YMF744
Toshiba Satellite 2805-S501 - Yamaha YMF754
Compaq Presario 1805 - ESS ES1869
IBM Thinkpad A21p - Crystal Semiconductor CS4624
Reply 1 of 15, by cyclone3d
Shouldn't be that difficult. The base work has already been done:
MIDIto - relocate hardcoded port 330h to somewhere else
Yamaha YMF7x4 Guide
Reply 2 of 15, by Falcosoft
cyclone3d wrote on 2021-11-22, 06:25:
It's much more difficult. That Midi port forwarding tool has nothing to do with what OP asked. Skyroads and other games that use OPL/FM synth do not use Midi commands when they use port 220h/388h etc. but sends native OPL commands.These cannot be simply forwarded to a real Midi port (e.g. to 300h/330h) since Midi devices do not understand OPL commands.
OPL to Midi conversion is next to impossible. At best case you would get something that Ensoniq/Creative audio PCI cards tried to achieve (emulate OPL/FM synth through Wavetable synthesis) .That is horrible:
https://www.youtube.com/watch?v=3AZI07_qts8
Website, Facebook, Youtube
Falcosoft Midi Player + Munt VSTi + BassMidi VSTi topic
Reply 3 of 15, by root42
What would be much more feasible would be to incorporate an OPL2 emulator such as FMOPL (https://github.com/adplug/adplug/blob/master/src/fmopl.c) into a driver that intercepts writes to 0x388.
YouTube and Bonus
Reply 4 of 15, by crazii
Thanks! Just read the post and it seems only a 'port remapping' TSR for DOS, but I believe except that the port is one obvious difference, the real hardwares(OPL/GM) have different registers with different meanings, i.e. writing 1 to port 220h is one command for hardware A, but maybe another command to hardware B, that's why different drivers are needed. On the other hand, if you just relocate MPU401 GM to port X, then that port X still be a MPU401 GM interface, Adlib or Soundblaster will fail. I'm not totally sure but it's an educated guess based on my knowledge about programming.
Reply 5 of 15, by crazii
Falcosoft wrote on 2021-11-22, 08:19:
It's much more difficult. That Midi port forwarding tool has nothing to do with what OP asked. Skyroads and other games that us […]
OKay, that really hurt my ears🤣. myabe a larger (8m) wavetable will help?
Reply 6 of 15, by Falcosoft
crazii wrote on 2021-11-22, 09:09:
No. 😀
The problem is not the quality of the samples but the completely different methods of synthesis. FM synths are real programmable synthesizers. You cannot translate arbitrary FM generated sounds to fixed samples (whatever quality they are).
Samplers/Romplares/Wavetable synths are suitable for (GM) Midi since you know what kind of and how many instruments you have to implement beforehand. There are no such predefined instruments in case of OPL/FM synths. So the 'mapping' is not trivial at all.
Reply 7 of 15, by crazii
root42 wrote on 2021-11-22, 08:42:
This code is a little familiar to me, I recall some SDL ported DOS games are using it.Maybe DOSBox is using it but I don't quite remember. If the CPU calculation is not intense, I think it will be a good option.
EDIT: Then it will be a soft FM synth driver. Now it seems that soft FM synth will be better.
Reply 8 of 15, by crazii
Falcosoft wrote on 2021-11-22, 09:20:
No. 😀
Cool, new knowledge gotten. 😀
Reply 9 of 15, by Falcosoft
This is also open source now (Sound FX for Win 2000/XP):
http://www.softsystem.co.uk/products/soundfx.htm
Maybe it can be modified to work under Win9x when WDM drivers are used.
Reply 10 of 15, by crazii
Falcosoft wrote on 2021-11-22, 09:40:
This is also open source now (Sound FX for Win 2000/XP): http://www.softsystem.co.uk/products/soundfx.htm Maybe it can be modifi […]
Looks nice, unfortunately it only works on NT based system. Have you tried it? What's the difference from VDMSound (quality, performance, compatibility)?
Based on its driver nature I guess it's more convenient, but with less tunable options?
Reply 11 of 15, by Falcosoft
crazii wrote on 2021-11-22, 11:16:
Honestly when I last used WDMSound it did not have OPL/FM emulation at all. I have just seen that OPL/FM emulation was added to last version. So I have just tested and the OPL/FM emulation seems to be more mature in SoundFX compared to last version of VDMSound (2.04).
Reply 12 of 15, by crazii
Falcosoft wrote on 2021-11-22, 13:11:
Same here, When I last use VDMSound that's 15y ago, when I was in college. A few days ago I checked the latest version and it has more features.
With the SoundFX source code I think it will be more easier to port it to win9x (mainly API & driver model adaption) than inventing another wheel using FMOPL source.
Maybe I would like to try it, I wish I have more spare time and energy and skill to do that.🤣
Reply 13 of 15, by Plasma
crazii wrote on 2021-11-22, 05:58:
I've read some basics about FM synth and MIDI here: What's the difference between “FM synthesis” and “MIDI synthesis”? I'm not q […]
Background:
Ensoniq/Creative AudioPCI does exactly this and it sounds like absolute garbage. I had one back in the day and hated it.
Reply 14 of 15, by Falcosoft
crazii wrote on 2021-11-22, 13:28:
Since both Win98+ and WinXP can use WDM driver model it should not be that difficult E.g. you can use the same SB Live! WDM driver under both Win9x and WinXP.
Reply 15 of 15, by cyclone3d
I was thinking of the opposite... using FM as a MIDI synth such as is built in in Windows 3.x and MIDIOX.
To get an acceptable OPL to MIDI implementation, it would probably be required to have a program that could re-ahead the music data and convert in real-time or have per-program profiles for the converter.
Edit:
It should be possible using DOSBOX with dro2midi and then adding in a layer that plays the resulting MIDI files realtime.
What would be sweet, is if the converter would have a way to automatically name the MIDI files so when the game is run again, it would auto detect if that song had already been converted and would then just play the MIDI file instead of converting it from scratch again.
Yamaha YMF7x4 Guide
