First post, by Riikcakirds
Sound card is IPLAW35 CRYSTAL CX4237B-XQ3 (ISA).
After booting to DOS, the POST screen lists PCI devices and under that shows my soundcard detected as an ISA PNP DEVICE.
Then I have around 1 minute to initiate the card before it disappears and can't be detected by unisound or it's own dos driver.
I have noticed if I don't connect the 3.5mm stereo jack to lineout the card will sometimes not disappear, it will still be detected 30 minutes later but as soon as I plug in the 3.5mm jack back in to line out the card disappears from DOS. Motherboard is 440BX and has no other problems. Tried the soundcard in two other motherboards with different power supplies and it has the same issue.
Does this sound like a capacitor problem (they look in very good condition)?
