Reply 420 of 1058, by jcarvalho
root42 wrote on 2023-07-24, 17:26:MJay99 wrote on 2023-07-24, 16:57:jcarvalho wrote on 2023-07-24, 14:28:P.S. PLEASE IGNORE THIS ---> for some reason the old firmware also does not output sound... Maybe the card developed some fault but initialize correctly and passes the ram verification tool
I once had one of those I2C DACs with a lost channel - ended up simply being a bad soldering of the connector iirc - maybe worth redoing them (or the PCM5102 DAC).
Oh, and there is one common and easy to fall for mistake: make sure the cable is attached to the I2C DAC's connector and not the more prominent MIDI port - that happened to the best of us... 😉
Which incidentally also produces some kind of noise!
It is a shame but I have found the problem.... The speakers jack was pluged in the wrong connector.... Noticed that now... I pluged the speakers on the midi out. All is working 😁
I have opened an issue (#10) in the github, but it is not an issue, Ian, if you can please delete it...
