First post, by Ydee
- Oldbie
I wonder, if exist any option to reinstall the OS-imposed WDM soundcard driver with more suitable (for my purposes) VXD?
The sound card (Sound Galaxy PRO 16III 3D PNP, Aztech 2320) is found after the start of the W98SE and its WDM drivers are installed without the possibility of user intervention. However, these drivers do not work well or at all in DOS games, launched from W98SE. When trying to reinstall in Device Manager and guide it to the directory with .vxd and .drv drivers, the system refuses to change the driver, claiming that the most suitable driver is already installed.
Everything works perfectly in the W95, unfortunately there's another problem and so I'd like to run this card in the W98SE, just with .vxd drivers.
Is that somehow possible?
