First post, by ChrisTOTG
I don’t have a DAW because I am not a musician, but I’d like to set up a trial version of the sound canvas plugin for DOSBox (and input from my retro box).
Reply 2 of 2, by Falcosoft
RetroGamer4Ever wrote on 2022-10-12, 04:24:
You need a VST host, like the VST MIDI Driver.
https://github.com/Arakula/vstdriver/releases … g/v1.0.0-alpha3
If OP wants to use SC-VA plugin for DOS games then VST Midi driver is the worst choice. It is the only VST Host available that cannot use SC-VA in SC-55 mode that is ideal for DOS games.
(ref:
Re: Falcosoft Soundfont Midi Player + Munt VSTi + BassMidi VSTi
Re: VST Midi Driver Midi Mapper)
Both SAVI Host and FSMP are much better options in this respect (not to mention the horrible 500 ms latency of the above linked driver at GitHub).
Video tutorial for FSMP from Phil:
https://youtu.be/vSk9S1bkRS8?t=500
Website, Facebook, Youtube
