Reply 1160 of 1347, by vico
- Newbie
crazii wrote on 2024-02-08, 04:44:I tried that too, and I got the same results as yours. so I use Rufus to write its builtin FreeDOS image to the disk, and copy sbemu manually to the disk 🤣 . You may ask @digger how to use the image in a proper way.
Using MiniTool Partition Wizard I extended the partition of my USB device to 2GB and it worked, the file system was not corrupted, I was able to add the games, Freedos and SBEMU loaded correctly.
I don't know if I can extend it to 4GB since I haven't tried.
However, using the build UserBuild_2024.02.08_01-48 I couldn't hear the sound of any games, so I replaced the SBEMU files with those from build 1.0 beta 3 and with that I was able to hear the sound of the games on my HDA properly.
