First post, by Sphere478
There’s been a few threads asking about this, I got this 3.5mm jack mixer. It works pretty good!
Heads up. 😀
    819.25 KiB
Sphere's PCB projects.
Reply 2 of 25, by JayAlien
If only there was something for 5.1 systems
386sx25 SBP2 2M
P75(486) SB16 8M
P133 S3 Vir DX A64g 32M
P233MMX R128Pro A64 64M
Pii400 TNT2 Live! 128M
P3-1G V5 M80 256M
P3-1.4G R8500 A1 256M
A3200 9700Pro A2 512M
X6800 X850XT A2ZS 1G
E8600 X1950XTX Xfi 2G
QX9650 3870 Xfi 2G
i7-975 GTX570 Xfi 3GB
Reply 3 of 25, by Sphere478
JayAlien wrote on 2024-01-11, 04:08:
could not multiple of these be used?
Reply 4 of 25, by giantclam
Sphere478 wrote on 2024-01-11, 04:19:
In theory, yes ... 5.1 is Front L/R + Rear L/R + Subwoofer channel ... so you could use 2 x the stereo mixers touched upon here, and 1 x 4channel mono mixer for the sub channel ... which would give you 4 x 5.1 sources, mixed to a single 5.1 output.
Reply 5 of 25, by JayAlien
Also the center channel. It could be done with multiple units but it’s messy.
I’ve been on the lookout for a while, but there doesn’t seem to be 5.1 audio switches on the market.
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
QX9650 3870 Xfi 2G
Reply 6 of 25, by giantclam
JayAlien wrote on 2024-01-11, 05:12:
I've only seen 2 x 5.1 source switches... ie; https://www.aliexpress.us/item/2251832692939592.html
Reply 7 of 25, by darry
giantclam wrote on 2024-01-11, 06:16:
Why not re-purpose a component video + L/R (analogue) audio + coax (S/PDIF) switch for analogue 5.1 audio ?
Like this one : https://www.startech.com/en-ca/audio-video-pr … ducts/cpnt410ir
EDIT: I just realized I have that exact one, 🤣 . I'm not currently using it .
EDIT 2: See also the similar Atlona AT-CV41R
Reply 8 of 25, by JayAlien
Ah thanks. I do have a couple of component switches and I had considered them in the past. May have to revisit that project.
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
QX9650 3870 Xfi 2G
Reply 9 of 25, by BitWrangler
HDMI switches are getting around for cheap now, how hard is it to inject and extract audio in them do you think?
I've got a real fancy KVM I picked up some while back think I saw just a stereo jack on that, might be worth a try if you can grab one cheap.
Also in reserve is a rack/stack type AV source mixer think it does 5 or 6 to one, Realistic brand Tandy/RadioShack unit, that's in storage not sure what all it will do. At least stereo anyway.
4:1 serial switches should probably have enough lines to run thru, 4:1 parallel would def, but I had the impression that a 4:1 serial might be easier and cheaper to get than 4:1 parallel, lots of 2:1 around. But then you might have impedance matching and noise probs.
Also possible is just get a load of analog switch ICs and making an array turning things on with buttons and latches.
If you wanna go super low tech, you can find a junked projection TV and pull the input/output panel off the back, there's some that have like 20 RCA sockets, 2 inputs in both regular RCA and Component plus outputs etc, anyway, just wire that up and use it as a plugboard/patch panel with flying RCA leads.
Reply 10 of 25, by wbahnassi
I hand-made a custom passive mixer for my brother's setup. He has two PCs outputting 5.1, and wanted to also add an MSX that outputs mono. I took a couple of those small prototyping boards and populated them with 3.5mm jacks for inputs and outputs with a few resistors. The end result looks a lot like that commercial multi-input small passive mixer. Works great and is cute and needs no PSU.
Of course it has the same disadvantages of any passive mixer, but I personally can cope with those to save on one more power brick added over my outlet.
Reply 11 of 25, by Tempus
I use this 1988 mixer with a 486 and a Pentium 3.
    1.71 MiB
Akumajō Dracula: Belmont's Theme Roland MT-32 | Yamaha YM2151
Reply 12 of 25, by darry
BitWrangler wrote on 2024-01-12, 05:07:
HDMI switches are getting around for cheap now, how hard is it to inject and extract audio in them do you think? […]
I do not recall having seen commercial products that do analogue 5.1 to HDMI. A DIY Raspberry Pi solution seems feasible, though.
Reply 13 of 25, by Pierre32
Sphere478 wrote on 2024-01-11, 02:31:
Heads up. 😀
I used to shy away from passive mixers, but recently I threw one of these very things into a setup and I'm quite happy with it. It does the thing.
242.22 KiB
Reply 14 of 25, by dionb
darry wrote on 2024-01-12, 15:40:
Pretty much any modern USB sound 'card' has ADCs galore. Not at all sure about quality of additional A->D->A conversions though, and things could get very expensive if you need to do a *lot* of inputs.
Reply 15 of 25, by Gmlb256
Heads up. 😀
Got one of these passive mixers for my retro computer and I'm impressed, it can handle all four inputs from multiple sound cards quite well. 😁
    155.97 KiB
Reply 16 of 25, by Sphere478
Nice! :p
I wonder if there is a version with more ports🤔
Reply 17 of 25, by Shponglefan
Sphere478 wrote on 2024-01-21, 15:16:
Nice! :p
There is the Edirol (Roland) M-10MX. It can support up to 5 stereo devices. It's also powered so there isn't any volume loss with an unpowered mixer. It even has a headphone jack and digital outs.
It's the most compact option I've found that can support 5 stereo devices.
552.12 KiB
Beyond that you're probably looking at rack-mount options such as this ART MX822 (8x stereo).
150.05 KiB
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 19 of 25, by BitWrangler
Randomly came across some stuff in Elektor 303 projects book...
https://archive.org/details/Elektor_Electroni … ge/n13/mode/2up
Circuit 006 and 009 look interesting for these purposes. Note 006 is awkwardly named it's digital selection of analog audio and is also mono source to mono output so you'd need to double it up for stereo.
