First post, by Scythifuge
- Oldbie
Greetings,
I have attached a pic of the same model of K2y-Pro16 I have recently acquired. The CD Audio ports on the card are labeled Sony, Mitsumi, and Panasonic. Does this mean that I need a compatible drive from one of those brands for CD Audio to work, or is one of them also plain-IDE compatible, or can I use any one of the ports? I am swapping cards around and need to dig out a couple of cables before I can test. The CD-ROM drive in my 486 is an NEC Quad Speed (CDR-273.)
Also, does anyone know if there is anything else I should know about this sound card? I couldn't locate Diamond-specific drivers, but I used a driver from the Dos Days site and got the test 8-bit and 16-bit sound tests to play. I also notice a daughterboard connector. I have a generic daughterboard and I think I have either a Wave Blaster 1 or 2 and am thinking about buying the Dream blaster.
Many thanks!
Scythifuge
