Skalabala wrote on 2021-08-04, 19:30:
Ok the problem was the graphics card was overclocked too much.
@550Mhz I get 116Fps with no in game tweaks. No tweaks tried to gain FPS in Quake.
Playing the game itself is silly fast with FPS going up to 300!!! On 1024x768 :0
116 fps in quake2 is really good.
My record so far in quake2 with my Geforce 256 DDR is in the 140s.
I cant remember witch driver it was. I ended up not using that driver since I lost some fps in quake3.
Edit: btw. I have made a custom version of both quake3 and quake2 with extremely compressed textures and sounds. I have reduced the quake3 pak files with 350 megabytes if data, and quake 2 with something similar. Send me a PM if you want to try ut out. It is basically a low res and low res sound mod. These versions made wonders on low specs computers. I have one computer with a pentium 233mmx @266 with a riva 128. I got 12fps with stock settings in quake2. With my custom quake2 with custom exe and custom cfg I now get 32 frames per second in timedemo1 map demo1.dm2
