Hi root42,
I was busy with other stuff (both daily routine and other microelectronics projects) and haven't had time to check on the VOGONS forum.
Yes, I finally reprised working on the ISA video card. The goal is to make it more stable and easier to be replicated by hobbyists.
I don't have anything ready yet but I have very good results from an active memory driver circuit that I was working on. It is going to be an all-SMD design on two small interposer PCBs that will be pluggable directly in place of the old dampening resistors.
I just took the time to build a second graphics card because the first one is actually in use in my main retrocomputer. And since I have all the parts and initial revision PCBs (the ones with the RAMDAC adapter) I just assembled another test subject.
This time I went with sockets for easier improved memory driver interface.
The LA probes adds some capacitive loading on the memory refresh lines which introduces some real-time visual artifacts. But that is as expected. I can filter those out "mentally", while regarding the VGA CRT output.
The logic analyzer shows that the /D* output signals are timed as it should, even though their /* reference input signals are not that perfectly shaped in time.
As I was saying, despite the unshielded wire forest, I already obtained very good results. No flicker and no random pixels igniting on the screen anymore. The colors are very bright and accurate as well.
However it will take some more time until I can release the updated memory driver circuits. I just want to make sure everything works as expected in the first place.
Cheers,
A.
TX486DLC / 40 MHz | 32 Mb RAM | 16-bit ISA Backplane | Tseng Labs ET4000/W32i 2 Mb | I/O Interface | Audio Interface | PC Speaker Driver | Signal View Interface
3.5" & 5.25" FDD | 4 x 512 Mb CF | HP 82341D Interface | Intel EtherExpress 16
