First post, by Snookeroo
Greetings venerable Vogons of all seeing retro knowledge!
I have been completing a playthrough of Half Life Opposing Force on my Windows 98 machine. It is a 1.4GHz Tualatin build with 128mb of video memory, so it certainly over qualifies for running the game.
It is so dark that I can't see anything without the night vision mode on! For the entire game I just thought it was meant to be this way, until I had to look at a guide for something in one of the final chapters. I saw some screenshots and thought "my game certainly doesn't look like that!".
If this is a glitch it's a very strange one, because it's not completely pitch black. In rooms where there is a light source I can slightly see my surroundings, but it's extremely dim. As you can see in the attached screenshot, I am able to see light sources and things like glowing green ooze on the ground. It's even really dark during the outdoor segments, but I think maybe it's meant to be set at night? Not sure.
I have fiddled with all the video settings; nothing helps.
I can't find anything online about this problem. Has anybody else ran into it before? I'm running version v39 1.0.1.5 of the game from my original old CD-ROM, as pictured.
Cheers!
Reply 1 of 7, by Pierre32
I assume your video card and the drivers you're running are going to be an important part of the troubleshooting here.
Reply 2 of 7, by Snookeroo
Pierre32 wrote on 2022-02-28, 07:45:
Good point! Here you go. I'm using that "41.09_win9x" you see in the bottom right there.
Reply 3 of 7, by RandomStranger
Does the base game look right?
Do you run it in DirectX or OpenGL rendering?
What happens if you switch to the other one?
Reply 4 of 7, by Snookeroo
RandomStranger wrote on 2022-02-28, 08:13:
The base game ran perfectly. It's using Direct3D by default. I tried Software and OpenGL, neither of them made a difference.
Reply 5 of 7, by Stiletto
Moved to Marvin -> Video.
do the Fandango!" - Queen
Stiletto
Reply 6 of 7, by darkenedroom
I notice your running on a crt, and you've said you've fiddled with the video settings, but you don't say which ones, but have you tried adjusting the monitor brightness? I know it seems a bit obvious but I've had my fair share of those sort of face palm moments, so just to make sure you've eliminated that as a cause.
https://www.tales-from-darkenedroom.com/ - Retro PC gaming on Windows 10, technical aspects, flight sims and space sims a speciality
Reply 7 of 7, by leileilol
Try setting gamma above 0 in the console, like 2.5 (which doesn't actually adjust screen gamma, but processes the lightmap texture on map load, as it's a game from the video driver dark ages (PUN COMPLETELY INTENDED))
