First post, by Bohemond1099
I cannot figure this out; I disabled vsync in the nvidia control panel/settings , but my Geforce 2 Pro refuses to run above 75FPS; which is refresh rate of the monitor. I have confirmed that my Voodoo 3 3000 and Voodoo 5 5500 cards have no issue going above 75FPS in games; I have tried the latest drivers for the Geforce 2 as well as several older ones back to 2000 and 2003; same issue. Does anyone know a fix for this please?
specs: Pentium III 1Ghz/512MB RAM/Windows 98SE
Reply 1 of 5, by pancakepuppy
I've had this issue with particular driver versions. Which did you use? Can you try a later one?
Reply 2 of 5, by The Serpent Rider
RivaTuner. The answer is always RivaTuner.
Reply 3 of 5, by Aebtdom
The Serpent Rider wrote on 2022-09-02, 18:02:
If that does not work, you are doing it wrong. Disabling vsync in rivatuner always works with nvida cards and most ati.
Builds:
Xp3000+ gf3 ti200 + vd2 SLI 12MB + 768MB + SB live @ WinXP & 98 Dualboot.
P2 350mhz + Diamond Viper V550 + 3Dfx Voodoo 2 12MB + AWE64 + 128MB SDR @ msdos / win98.
Reply 4 of 5, by Bohemond1099
I went all the way back to detonator drivers and with those; disabling vsync actually took effect.
Reply 5 of 5, by Bohemond1099
pancakepuppy wrote on 2022-09-02, 18:01:
Later drivers were the problem; going back to old detonator drivers allowed disabling vsync to actually work.
