First post, by psychofox
Just recived Asus p5A-B motherboard for my new ultimate DOS gamer.
IMHO one of the best SS7 boards
It has K6-2 266 already installed, i think i should probably change it to Pentium MMX 200 ?
And the main question - i have couple of choices for graphics card, which one would you choose?
I am thinking to use Voodoo Banshee but i have no idea how it performs in pure DOS and older dos games compatiblity?
But also have Voodoo I 4mb which i could pair with one of these:
SIS 6326 AGP
ASUS S3/virge GX2 PCI (it would match perfectly with mobo 😀 )
Powercolor S3 virge/GX2 AGP
S3 virge /DX (unknown manufacturer)
Reply 1 of 9, by Shagittarius
The Banshee is probably overkill for a 200MHz DOS system, but its got a kick ass and highly compatible 2d engine on it too. I say go with the Banshee, I have one in my P-133.
Reply 2 of 9, by Joseph_Joestar
If you're primarily focusing on DOS gaming, the Virge + Voodoo1 combo will provide you with the best overall compatibility.
See here: http://gona.mactar.hu/DOS_TESTS/
Reply 3 of 9, by psychofox
Joseph_Joestar wrote on 2022-09-27, 17:07:
Tried that combo. Powercolor Virge/gx2 has very nice and sharp picture. But combined with voodoo, image quality is way below average, i dont know if it is faulty voodoo or loop cable? Anyway, what i lose on DOS gaming, if i use Banshee?
Reply 4 of 9, by TrashPanda
Nothing, the banshee has excellent DOS compatibility, great image quality and with a few Autoexec tweaks can run Voodoo1 games just fine.
Its a great card.
Reply 5 of 9, by Shagittarius
psychofox wrote on 2022-09-28, 05:19:
I think you lose the ability to play Pinball Fantasies.
Reply 6 of 9, by Joseph_Joestar
The image degradation is the consequence of using a pass through cable. I get around it by connecting the S3 card directly to the monitor while playing 2D games, and only hooking up the Voodoo1 + pass through cable if I'm playing 3D games. Kinda tedious, but I mostly play 2D stuff on my the DOS system so I don't change this very often.
As others have said, the Banshee is a very nice card as well. So if you want an all in one solution, it's a good alternative. The Voodoo1 might be slightly more compatible with some early DOS Glide games, but you can probably work around that. See here: Voodoo 2 DOS Glide compatibility matrix
Reply 7 of 9, by TrashPanda
Joseph_Joestar wrote on 2022-09-28, 07:34:
The Banshee should in theory be more compatible with Voodoo1 games due to how similar the two are aside from the Banshee being a cut down Voodoo2.
Reply 8 of 9, by psychofox
I personally like S3+ V1 combo more too, it is more period correct and looks way cooler 😀 so i keep it like that for now. Maybe i should find an kvm switch for easy swap between S3 and Voodoo?
Reply 9 of 9, by Joseph_Joestar
psychofox wrote on 2022-09-29, 08:13:
Yes, using a KVM switch is a known good way to avoid the image quality issues which arise when using a pass through cable.
