First post, by matze79
does anyone here Own a STB Powergraph 64 Video VLB with S3 Trio 64 and can provide a Dump of the BIOS ROM ?
Thanks
Matthias
Reply 1 of 8, by douglar
Is that VRAM or DRAM?
I have a VLB Diamond Stealth64 DRAM which has an S3-Trio64 chip and 64bit memory. I'll post that if you think it's worth the outside chance that it works with your board.
Maybe try the bios posted here first: http://vgamuseum.info/index.php/component/k2/ … m/357-s3-trio64
Reply 2 of 8, by matze79
My Board is a bit special.
I specifically searching for this BIOS best in version 1.4 but all others also are welcome.
Thanks !
Reply 4 of 8, by weedeewee
That board looks like it's someone's personal project and not some mainstream card.
Where did you get it from ?
Do not ask Why !
Reply 6 of 8, by megatron-uk
That's a really nice looking board for a homebrew design.
How much of it would be directly translatable to a purely ISA design? By that I mean was this card only possible because the Trio64V+ has hardware level PCI and VLB compatability?
https://www.target-earth.net
Reply 7 of 8, by matze79
Yes Virge 325 and Trio64V+ still have VLB Support, i don`t think it would be easy/possible to make a ISA Design with that Chip 😀
This Card was made by Madao (here on vogons) and is really fast.
But i have no HighEnd VLB Board, i only have Shuttle HOT-491.
i really would appreciate the PowerGraph BIOS, to rule some things out.
Reply 8 of 8, by 386_junkie
I can dump the Powergraph64 Bios... I believe it is only version 1.2 though if thats ok?
