First post, by envagyok
Hi there!
I have Matrox G400 feaphic card what built with circuit board as G400 max with fan connector, and 5ns ram, with passive cooler.
I have defect G400 max with its own cooler and fan.
How can i mod the g400 to g400 max?
Just a bios flashing, or need change maybe an oscillator ?
I try with matrox tuning utility and see gpu and ram clock is divided from 250mhz quarts oscillator.
Reply 1 of 3, by Putas
I guess the utility shows so called base "clock" from which particular clock domains are derrived. And the base value is from bios, so flashing it would be the way.
Reply 2 of 3, by swaaye
Try MGATweak. I used it for years to overclock my G400.
https://alt.3dcenter.org/downloads/mgatweak.php
You can fairly easily do a BIOS overclock as well. These cards use text-based variable configuration called "pins" that you flash to the card to set various things including the clock speeds. I suggest using software overclocking instead because you're less likely to run into problems like a corrupted BIOS, non-working config, etc.
https://web.archive.org/web/20040110103309/ht … .pl/gbm/matrox/
Reply 3 of 3, by envagyok
I prefer to flash bios.
With which tool can i make it?
Or when i mod pins, that always wotking, after driver load?
