First post, by rain
As titled says im using voodoo3 3000 agp with my matsonic socket 478 mobo.
But desktop items not sharp , tried different refresh rates but no luck. Using 1024-768 res. Is it about drivers that im using or monitor bug? Thanks for answers
Reply 1 of 6, by bloodem
Did you try your monitor's Auto Adjust button?
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 2 of 6, by sysctl
I have two voodoo 3 3000 and both of them are very sharp on both CRT and LCD displays. Definitely not drivers.
Most likely it's monitor setting, maybe you can tell what monitor you're using.
Reply 3 of 6, by darry
It could be the monitor (or a monitor setting) , it could be the VGA cable, it could be the video card.
Try a lower resolution to see if it helps and maybe a try a different VGA cable, if possible.
What is the brand and model of the monitor ?
Reply 4 of 6, by BitWrangler
In addition to encountering every problem darry mentioned, I have also seen a bad motherboard make for a blurry display with high frequency noise passed through from failing voltage regulation.
Reply 6 of 6, by darry
BitWrangler wrote on 2024-04-18, 15:41:
I don't recall witnessing that last one. Thank you for bringing it to my attention as a potential issue.
