First post, by kvm7365
Hi! Vogons!
I am trying to repair an old ISA VGA card - ATI VGA Wonder-16 V5.
It look like this:
93.96 KiB
Could you please help me with missing bios dumps for my ATI Wonder 16 V5( EVEN and ODD ).
BIOS from ATI VGA Wonder-16 V2 donot work 🙁
Thank you in advance.
Reply 1 of 10, by dominusprog
Have you checked this?
https://vgamuseum.info/index.php/companies/it … -ega-vga-wonder
Reply 2 of 10, by kvm7365
dominusprog wrote on 2024-04-23, 13:35:
Thanks!
I have checked this.
VGA88 bios not working with my card.
With EDGE-16 Bios , VGA output of my Wonder-16 seems to be OK (tested only DOS mode with 256Kbyte onboard RAM)
The differences of Edge-16 and my Wonder-16 V5 cards are max size of onboard RAM (EDGE-16 only 256Kbyte, Wonder-16 - 256 or 512 Kbyte) and Wonder-16 onboard EGA output.
It will take me some time to test my Wonder-16 V5 card EGA output and 512Kbyte onboard RAM with EDGE-16 Bios, because I need EGA monitor and additional chips to add 256Kbyte RAM .
I am still looking for original Wonder-16 V5 Bios.
Reply 3 of 10, by CoffeeOne
kvm7365 wrote on 2024-04-23, 10:05:
Hi! Vogons! I am trying to repair an old ISA VGA card - ATI VGA Wonder-16 V5. It look like this: ati wonder -16 V5.jpg Could yo […]
Hi! Vogons!
It look like this:
How hard would it be for you to make a picture and add it to the thread?
Reply 4 of 10, by dominusprog
Well, I've found these links too.
https://archive.org/details/ati-vga-wonder-16 … s-odd-even-roms
https://forum.vcfed.org/index.php?threads/nee … ios-dump.39842/
Re: ATI Wonder - bios information check
Reply 5 of 10, by kvm7365
This is my Wonder-16 V5 board with EDGE-16 bios (not original)
1.41 MiB
The main difference Wonder-16 V5 card from earlier Wonder-16 cards is another clock former - chip ATI18810 1. To my mind, this is the main reason , why bios from earlier Wonder-16 cards not working.
Reply 6 of 10, by weedeewee
kvm7365 wrote on 2024-04-23, 19:12:
You could split the edge bios found in the bios download on vgamuseum in an EVEN & ODD part.
program you can use for that is romwak https://github.com/freem/romwak/releases
for example :
romwak_x32 /b vgaedge16.vbi odd.bin even.bin
or
romwak_x64 /b vgaedge16.vbi odd.bin even.bin
depending on if your windows is 32bit or 64bit.
Do not ask Why !
Reply 7 of 10, by kvm7365
weedeewee wrote on 2024-04-23, 19:44:
It's not a problem for me to split bios dump to EVEN and ODD parts. It's problem for me to find original bios dump for Wonder-16 V5 revision.
Reply 8 of 10, by weedeewee
kvm7365 wrote on 2024-04-23, 20:20:
Ahha! and you have tried that vgaedge16.vbi bios file ?
Do not ask Why !
Reply 9 of 10, by kvm7365
weedeewee wrote on 2024-04-23, 20:47:
Yes. I have tied vgaedge16.vbi bios file. I have splited it to EVEN and ODD and wrote to EPROM.
I have wrote about results few post earlier.
Reply 10 of 10, by weedeewee
Thanks for clarifying that.
Do not ask Why !
