Reply 221 of 648, by candle_86
Non OC
AMD Opteron 144 (San Diego @ 1800mhz), 1gb OCZ Gold DDR500, BFG 6800GS OC 92.91, Epox 9nda3j 5.10, Soundblaster Audigy, Window XP SP3
158.6 KiB
OC
AMD Opteron 144 (San Diego @ 2474mhz 275 bus 4x HT), 1gb OCZ Gold DDR500, BFG 6800GS OC Unlocked 16pp6v @ 425/1100 92.91, Epox 9nda3j 5.10, Soundblaster Audigy, Window XP SP3
    162.76 KiB
Reply 222 of 648, by Standard Def Steve
Time for some more Ivy Bridge fueled fun. 😀 This thing could probably hit 600 frames at 4.6GHz, but I'd rather not take this CPU beyond 1.25v.
Core i7 4930K @ 4.5GHz, Asus GTX 970 (347.25), 32GB DDR3-2133 CL9, Asus Rampage IV Gene (x79), onboard audio, Win7 x64
1024x768 Ultra:
CPU usage during the timedemo peaks at 14%, so the game is nearly maxing out two threads, but not any more than that. DX12 can't come soon enough. 😀
Reply 223 of 648, by JayCeeBee64
Rank Retired
Retired
Finally had a chance to do this ^^:
Pentium III 800EB, Asus CUSL2-C (Socket 370), 512mb PC133 SDRAM, NVIDIA GeForce 3 Ti 200 64mb AGP (30.82 WHQL drivers), Turtle Beach Santa Cruz, DirectX 9.0c, Windows XP SP3.
1024x768 Ultra Quality=6.0
Can't believe what I got with stock settings; I'm not done yet, though. I got a couple of Celerons on hand (400MHz Mendocino and 600MHz Coppermine), time to give them a run as well 😁
Ooohh, the pain......
Reply 225 of 648, by candle_86
AMD Opteron 144 (San Diego @ 2618mhz 290 bus 3x HT), 1gb OCZ Gold DDR500, BFG 6800GS OC Unlocked 16pp6v @ 430/1200 92.91, Epox 9nda3j 5.10, Soundblaster Audigy, Window XP SP3
155.17 KiB
Reply 226 of 648, by Skyscraper
candle_86 wrote:
darn ive hit a wall, board wont go over 291 bus, at 292 it wont boot into windows no matter what 🙁
I do also own an Epox 9nda3j board, I use mine with some dual core Opteron and an Asus Geforce 3 as a video capture system. My board did not want to go over 300 reference clock either if I remember correctly. Repasting the chipset heatsink and making sure there is a working fan on it gained me a few MHz.
Nice score at 2.6 GHz though 😀, pretty much equal to my stock scores with the FX55 so we get about the same scaling. We need to figure out Steves and havlis secrets! Hypothesis number one, they are not using Doom 3 v1.3/v1.31
Reply 227 of 648, by candle_86
I'm curious myself, but I'm limited to the steam version, then using an old 1.30 nocd on the steam copy so i dont have to run steam in backgroud
Reply 228 of 648, by Skyscraper
Well that explains why our systems perform similar, we are using exactly the same version. I think using the Steam version without 1.30 nocd also performs the same but Im not totally sure
Reply 229 of 648, by candle_86
Well im trying to find a physcial copy of doom3 retail to test with 🤣
Reply 230 of 648, by havli
Doom3 v1.3 indeed runs slower. I had no idea until now... patches usually bring more speed, not take it away. 😊
Here is screenshot of the 1.3 timedemo - 104.3 fps.
Same hardware and configuration as before.
I must try harder to get back to the first place. 😀
Reply 231 of 648, by Skyscraper
havli wrote:
Doom3 v1.3 indeed runs slower. I had no idea until now... patches usually bring more speed, not take it away. :blush: […]
Well you are still on top for now 😀
Where are my Doom 3 discs...*turns apartment up side down* 😀
Reply 234 of 648, by tincup
Hmm this is interesting. I'm running an original boxed copy with the v131 patch. They dropped DRM from v12 onwards I think - at least I'm not prompted for disks at any rate. Maybe I'll re-install v1 to see the speed diff..
Reply 235 of 648, by candle_86
yea im searching for mine, when they had it on steam during one of the sales i got it and roe for i think 9.99 and i put up my disks, that was a few years ago.
Reply 236 of 648, by candle_86
well couldn't find my original disk, but good news the Steam CD key for Doom3, not BFG but original doom3 works fine with retail disks, I managed to get a buddy online to rip me iso's of his original disks and am installing them with my steam doom3 key lets give this a whirl 🤣
Reply 237 of 648, by candle_86
Same Settings as previous OC for Opty
170.61 KiB
stock settings opty doom 1.0
144.63 KiB
Reply 238 of 648, by Standard Def Steve
I'm running the retail edition I bought back in 2005 without any additional patches, so it's gotta be one of the earlier versions.
